  Floor light issue
Floor light issue by Jason88Notchie
Started on: 09-19-2016 10:04 AM
Replies: 20 (351 views)
Last post by: Jason88Notchie on 09-23-2016 07:07 AM
Jason88Notchie
Report this Post09-19-2016 10:04 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had an interesting issue this morning on my way to work. I was driving and noticed my floor lights were on. Dome light off. Flipped the dome light on and off no change. Pulled up to a light and opened the door and the floor lights turned off and the dome light came on as normal. When I got to work I had to pull the bulbs to keep the battery from draining.
It seems like a reverse polarity issue, but not sure what caused it. Wasn't like that when I parked the car last night that I know of. I would think I would have come out to a dead battery this morning. Anyone else run into this issue?
Total ratings: 568
Report this Post09-19-2016 11:14 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
fuse is blown
See my Cave, Sneak Path
Blacktree
Total ratings: 350
Report this Post09-19-2016 02:28 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with the Ogre. Check your fuses.
Jason88Notchie
Report this Post09-19-2016 03:39 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Ogre. Just got home from work and checked. The culprit....blown BATT fuse. I'm off to the parts store for a fuse and some extras for the extra fuse bank. Only had one 5 amp fuse in there. My radio has been flaky too. Wonder if that has anything to do with it.
Jason88Notchie
Report this Post09-19-2016 04:29 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jason88Notchie
Member since Oct 2009
I pulled a 20 amp fuse out of the BATT bank. Shouldn't it require a 25 amp?
Blacktree
Total ratings: 350
Report this Post09-19-2016 04:51 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe it's 20 amp.
Jason88Notchie
Report this Post09-19-2016 04:56 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok thanks. The fuse may have blown for a reason...don't want to put a larger fuse in there and fry something.
Blacktree
Total ratings: 350
Report this Post09-19-2016 06:04 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update: according to the repair manual, it's a 20 amp fuse that powers the dome lamps, horn relay, radio clock, and cigarette lighter. If the fuse blows again, I'd check the horn relay and the cig lighter. They're the most likely culprits.
Jason88Notchie
Report this Post09-19-2016 06:24 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow. Went to plug in the fuse and it had a small arc. Tried again and the arc was larger. I stopped there......
Like I said before, the radio was flaky and appeared that it didn't have power for a couple weeks. No light issue though until this morning. After the arc the radio clock turned on but radio doesn't work. could the radio be flaking the circuit?
Total ratings: 290
Report this Post09-19-2016 08:30 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check for a coin in the cigarette lighter socket. Take it out and unplug it and see if the trouble clears.
That or the horn or the radio, but my guess is the coin in the lighter socket.
[This message has been edited by phonedawgz (edited 09-19-2016).]
Jason88Notchie
Report this Post09-19-2016 08:48 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Phonedawgs. No coin in the socket. Checked that already. Why such a big arc when trying to replace the fuse?
Total ratings: 290
Report this Post09-19-2016 08:57 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of those items is shorting to ground. Don't try a bigger fuse. Unplug the items that are shown on to be powered by the fuse and see which one stops the fuse blowing. If you didn't yet unplug the cig lighter that would be the first for me. It's easy to get to and still seems most likely even without the coin.
Any chance the Orange wire that connects to the lighter circuit is not on it and has fallen onto a screw and is shorting to ground?
Since the radio is still doing something I would put that low on the list. But unplugging the radio will eliminate it from the circuit/
Any chance there has been damage to the wiring harness? If you haven't seen it, consider it fairly unlikely.
To eliminate the horn from the circuit unplug the horn relay
While it takes a few fuses, troubleshooting a direct short is much easier to do than troubleshooting a poor short to ground or an intermittent one.
Total ratings: 568
Report this Post09-19-2016 11:49 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lighter socket can have other problems blowing Batt fuse.
Unplug the socket.
See my Cave, Lighter
Batt circuit is memory power to radio. GM Radios often won't turn on w/o this but won't normally blow any fuse when radio is bad.
Could be a jam switch broke (front of door frame) and allow wire(s) to short to frame.
Horn switch etc can short out too.
Unplug relay then steering column to quick test
[This message has been edited by theogre (edited 09-19-2016).]
Total ratings: 460
Report this Post09-20-2016 08:49 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The trunk light is also on the same fuse as the courtesy lights. (At least mine is, but mine was added later. Didn't come with it.)
Jason88Notchie
Report this Post09-21-2016 06:01 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
My trunk light is functional but no bulb. I pop the hoods at shows and want to avoid the battery drain. I also have the front trunk light too. I should replace the bulb in that one though, or have one on hand. Could come in handy.
Jason88Notchie
Report this Post09-22-2016 07:09 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Issue is resolved. I disconnected the neg battery cable, plugged in the 20 amp fuse. Reconnected and all systems are normal.
Now to replace those floor lamps with red LEDs.
Total ratings: 568
Report this Post09-22-2016 09:39 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely the battery will die because have too much power draw w/ key off.
Nothing should draw enough power to spark on Batt fuse.
Iffy lighter and/or socket can be big problems or even start a fire.
Jason88Notchie
Report this Post09-22-2016 09:58 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wouldn't the fuse hopefully blow before that happens?
I had my cell phone charging off the lighter for a good part of the day before I recognized the issue the next morning. The charger plug did get pretty warm to the touch when I unplugged it. Do you think the power draw from the phone over that period of time may have blown the fuse?
[This message has been edited by Jason88Notchie (edited 09-22-2016).]
Jason88Notchie
Report this Post09-22-2016 11:29 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Jason88Notchie
I put the LED floor lights in......
Total ratings: 568
Report this Post09-23-2016 01:19 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
No.
Not by itself. All USB car chargers get warm to hot because they just regulate 12-15v down to 5v 1a to close to 3a max.
[This message has been edited by theogre (edited 09-23-2016).]
Jason88Notchie
Report this Post09-23-2016 07:07 AM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
[QUOTE]Originally posted by Jason88Notchie:
No.
[/QUOTE]
Ok. Thank you Ogre. I'll keep a close eye on it and dig into it over the weekend.
[/QUOTE]
[This message has been edited by Jason88Notchie (edited 09-23-2016).]
