  Passenger side rear quarter panel scoop
Passenger side rear quarter panel scoop by 85fieroguy
Started on: 08-23-2016 08:57 PM
Replies: 1 (195 views)
Last post by: seajai on 08-23-2016 10:53 PM
85fieroguy
Report this Post08-23-2016 08:57 PM Click Here to See the Profile for 85fieroguySend a Private Message to 85fieroguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found some Mustang ? scoops for rear quarter panels. Question..want to " vent" or open up the passenger side quarter panel with a scoop for more air into engine. Without taking off the panel. can I drill a pilot hole and enlarge the hole for an air intake under the scoop. Need advise before I screw up.
seajai
Total ratings: 52
Report this Post08-23-2016 10:53 PM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is a pic of that area. This is my car and the cold air intake I added. The scoop needs to be closer to the wheel well otherwise you will hit structure. You may want to remove the inner wheel liner for better access.
