Unplug the C502 connector leading to the tank. There are three wires on the tank connector. Tan/White is power to the pump. Pink is the gauge wire. Black is ground. With the connector that runs to the body harness (not the one that runs to the tank), with the key on (engine off) short the pink wire to the black wire while someone looks at the gauge. The fuel gauge should move to E. If this fails then you have a trouble with the gauge or the wiring. If this passes then look at the tank sender.
If you know how to use an ohm meter, you can check the sender in the tank before you drop the tank. On the connector that leads to the tank measure the resistance between the pink wire and the black wire. A correctly working sender will give you a reading between zero (empty) and 90 ohms (full).
[This message has been edited by phonedawgz (edited 07-04-2016).]
