  N* Throttle body IAC values
N* Throttle body IAC values by crash41301
Started on: 04-17-2016 12:30 PM
Replies: 4 (133 views)
Last post by: crash41301 on 04-18-2016 05:30 PM
crash41301
Report this Post04-17-2016 12:30 PM Click Here to See the Profile for crash41301Send a Private Message to crash41301Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ive got a Northstar TB on my 3800 SC engine. Using Hp Tuner to monitor values, the IAC is sitting at 0 and cant lower the idle any further than ~900 rpms. In the LSx world, people would generally close the hole in the TB blade. However, there is no hole in the TB blade. Is there a common thing people do to get around this? I was leaning towards using epoxy to close the IAC hole a bit, but didnt know if there was already a common work around?
Lou6t4gto
Report this Post04-17-2016 01:57 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not to Highjack, But WHAT is the "Reason" for "using" a Northstar Throttle body on a 3800SC to begin with?? Thanks
crash41301
Report this Post04-18-2016 01:55 AM Click Here to See the Profile for crash41301Send a Private Message to crash41301Edit/Delete MessageReply w/QuoteDirect Link to This Post
It's bigger, that's about it. Generally bigger will give more power if it's a bottleneck because your engine is out flowing the stocker. My understanding is you need to be pretty mod'ed to need a bigger tb though.
I've noticed alot of people use lq4 maf as well, perhaps this iac issue is the reason...?
Zac88GT
Report this Post04-18-2016 03:10 PM Click Here to See the Profile for Zac88GTClick Here to visit Zac88GT's HomePageSend a Private Message to Zac88GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Remembering back to my N* there should be a minimum idle airflow screw that stops the throttle from closing all the way. Have you backed that off yet?
crash41301
Report this Post04-18-2016 05:30 PM Click Here to See the Profile for crash41301Send a Private Message to crash41301Edit/Delete MessageReply w/QuoteDirect Link to This Post
I sure havent, and this is exactly why I was asking here. Thanks! I'll be checking that first thing
