  88 gt trunk sealing procedure.
88 gt trunk sealing procedure. by tomsablon
Started on: 11-08-2015 09:41 PM
Replies: 20 (468 views)
Last post by: 85 SE VIN 9 on 11-11-2015 11:03 PM
tomsablon
Report this Post11-08-2015 09:41 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
can anyone lead me to a thorough thread on sealing the trunk? i want to hit all the top areas that might cause water leaks. thanks!
Report this Post11-08-2015 09:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
What is a 'top area'? Sometimes water comes through the attachment screws for the wing.
Total ratings: 466
Report this Post11-08-2015 09:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what they're properly called, but it can leak around those "D" shaped plastic inserts located at either end at the top of a GT's trunk.
Thunderstruck GT
Total ratings: 99
Report this Post11-08-2015 09:52 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
This ^ ^ ^
tomsablon
Report this Post11-08-2015 10:03 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
just looking for a general to do list . i replaced the trunk gasket yet i still get water now and then without driving it. just leaks in somewhere. i figured if i hit all the typical problem spots that folks have found that i'd have it solved. thanks
Report this Post11-09-2015 06:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
well I think you have the list. It sounds crazy, but enough water can wick through those wing stand fasteners to make the entire bottom of the trunk wet after a normal rain. The other spot is the filler plates on each end of the trunk. You should be able to figure it out based on where the water is.
to fix: back off the screws a bit and put some silicone caulk under the head and re-tighten.
[This message has been edited by Gall757 (edited 11-09-2015).]
Total ratings: 466
Report this Post11-09-2015 06:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whatever they're called, that's what I was referring to earlier.
Thunderstruck GT
Total ratings: 99
Report this Post11-09-2015 07:02 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Silicone sealer will not be as effective as what the factory used due to vibration.
The factory used a form of body putty called Strip Sealer, Strip Caulk or more commonly known as Dum Dum.
Report this Post11-09-2015 07:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dum Dum!! I haven't seen that stuff since the 1980s! Can you still buy it?
Thunderstruck GT
Total ratings: 99
Report this Post11-09-2015 07:52 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely.
Total ratings: 466
Report this Post11-09-2015 07:53 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dum Dum!!
Reminds me of O/T.
tomsablon
Report this Post11-09-2015 10:29 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
so,,, what you're saying is the smart thing to do is use dum dum . where can i get,,, dum dum? where should i apply it?
Report this Post11-10-2015 08:43 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Although Dum Dum is probably the correct stuff from the factory, you would have to buy much more than you need, and there are many household caulks that will do the job. I applied silicone bathroom caulk to my leaky deck lid screws many years ago and it is fine. Auto paint supply stores may have the Dum Dum.
[This message has been edited by Gall757 (edited 11-10-2015).]
fierosound
Total ratings: 287
Report this Post11-10-2015 11:25 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I put a dab of this around the wingstand studs before installing. No leaks there.
85 SE VIN 9
Report this Post11-10-2015 11:57 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1 on the black silicone, I used it to glue the gaskets and stands down and then went all around the gaskets with it. Not an '88, but same problem.
Speaking of that problem, are you certain it's coming from the top? I put old floor mats over things in the trunk. This definitely showed that it was coming from the wingstand attachment points, but the main reason my carpet was wet was the lack of trunk. You should probably take the carpet out and see what's going on down there. My trunk stayed dry last winter, but that was largely due to extensive patching of large holes in the trunk itself.
tomsablon
Report this Post11-11-2015 07:11 AM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
yup . i have some of the black silicone. i'll take the plastic corner things appart and seal there. i'll also check out the wing stand for leaks.
i modified the trunk to get the exhaust on the sc 3800 the way i wanted it and heat shielded and insulated from underneath. no carpet in there yet. i'll slice up the old carpet and install once i'm sure there are no leaks from top. i sealed with urethane construction adhesive all joints below. i fiiled with water to test for leaks and siphoned/shopvaced out to be sure. it's got to be leaking from top somewhere. thanks
Thunderstruck GT
Total ratings: 99
Report this Post11-11-2015 10:26 AM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good luck on the temporary fix.
Report this Post11-11-2015 11:34 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Keep in mind the original fix has already proven itself to be temporary.
Thunderstruck GT
Total ratings: 99
Report this Post11-11-2015 12:45 PM Click Here to See the Profile for Thunderstruck GTSend a Private Message to Thunderstruck GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has it?
You are assuming the car was never disassembled.
tomsablon
Report this Post11-11-2015 10:21 PM Click Here to See the Profile for tomsablonSend a Private Message to tomsablonEdit/Delete MessageReply w/QuoteDirect Link to This Post
not confidence inspiring. termparary is not what i had in mind.
85 SE VIN 9
Report this Post11-11-2015 11:03 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Obviously not the problem I was having. It sure does seem to be coming from the top. However. Mine had some holes that I left. Making things watertight is usually not a good idea because some water inevitably gets in. With nowhere for water or moisture to go it causes rust or mildew. Most things have pretty good sized drain holes. Maybe that's what you need.
