  4.9 Running Rich
4.9 Running Rich by pdemondo
Started on: 11-07-2015 08:51 PM
Replies: 5 (606 views)
Last post by: olejoedad on 11-09-2015 08:06 AM
pdemondo
Report this Post11-07-2015 08:51 PM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
My 4.9 is running very rich. I can smell the fuel and the mileage is below 10.
I read the engine data at idle after the car warmed up:
BARO 27.74 "HG, 4.45V
LT FUEL TR CL 25
LT FUEL TR EN YES
LT FUEL TR (L & R) 104
COOLANT 214 degrees F
EGR DUTY 100%
ENTINE RPM 700-775
EXHAUST O2 (L & R) RICH
INJ (L & R) PW 5ms
ST FUEL TRM (L & R) 81
LOOP STATUS CLOSED
MAP 15.69 "HG, 2V
IAT 214 degrees F
O2S CRSCNTS (L&R) 0
O2S (L&R) vaires betwen 579-670mv
TPS SENSOR .51V
It would appear that the computer is getting the correct information that the car is running rich and is trying to lean the fuel.
So would this suggest that the fuel pressure regulator is bad or the injectors are faulty?
I did remove the vacuum line from the fuel pressure regulator and did not see any fuel there.
Could this also be a problem with the ignition? (bad wires, spark plugs, etc?)
I am going to autozone to borrow the fuel pressure set to see what I am getting.
Any other suggestions?
Total ratings: 207
Report this Post11-08-2015 09:36 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
O² sensor values you posted are pretty narrow range. In would replace them with new Denso units.
Total ratings: 328
Report this Post11-08-2015 01:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with Joe, replace the O2 sensor w a Denso unit. . The O2 sensor should fluctuate continuously at idle from around .15 volts to about .5 volts. This still could be a fueling problem though. If its a fuel pressure problem, you can measure the pressure at the rail to see if it is within spec or too high. About 38-43 psi is about normal. Also measure the pressure after you shut off the engine. If the pressure rapidly drops to zero then the regulator is bad or an injector is stuck open but this is a rare occurance. BTW, what scanner are you using?
SERGE144
Report this Post11-08-2015 01:47 PM Click Here to See the Profile for SERGE144Send a Private Message to SERGE144Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had a rich condition until I made sure I had +12v to the power steering ecm input, +12 to the fuel pump ecm input.
pdemondo
Report this Post11-08-2015 11:13 PM Click Here to See the Profile for pdemondoSend a Private Message to pdemondoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for all the input. It turned out to be a bad fuel pressure regulator.
I checked the pressure and it was high.
I swapped in the new regulator and the smell of unburned gas was gone.
After running a bit the O2 sensor start cycling as before and the LT and ST fuel trim started moving up indicating that the fuel mixture was leaning out.
The car is running much better now.
Total ratings: 207
Report this Post11-09-2015 08:06 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good deal, thanks for the feedback.
