  Calling all the Cadi 4.9 experts. Starter question.
Calling all the Cadi 4.9 experts. Starter question. by zmcdonal
Started on: 09-27-2015 10:27 PM
Replies: 11 (446 views)
Last post by: zmcdonal on 05-26-2016 09:38 PM
zmcdonal
Report this Post09-27-2015 10:27 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok I need some advice from the 4.9 guys. This isn't really Fiero related but I have a 91 Eldorado with a 4.9 and you guys know more and are a more reliable source than the cadi forums.
I need a new starter for my 4.9. I got the old one out but it is a super tight fit to remove without dropping the front exhaust and I'd rather not have to deal with that same fight putting a new one in if I don't have to, especially if I can end up with a better starter as an end result. I read a couple posts on here about people using the Alante gear reduction starters on their 4.9's. Is that a direct swap?
It's sort of fiero related because the cadi is my winter ride to keep my Fieros salt and rust free.
Thanks guys.
Neils88
Total ratings: 56
Report this Post09-28-2015 12:04 AM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I used the allante starter.... It was a direct replacement. Make sure you keep your starter bolts... They are tough to find!
Fieroking
Total ratings: 78
Report this Post09-28-2015 01:31 AM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Allante starter on my 4.9 works great.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
Total ratings: 461
Report this Post09-28-2015 01:34 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes. Bolts right on. I have one too. You won't be sorry.
manriquez
Report this Post05-26-2016 10:52 AM Click Here to See the Profile for manriquezSend a Private Message to manriquezEdit/Delete MessageReply w/QuoteDirect Link to This Post
is this the one you are talking?
did read somewhere the 4.9 will touch the fiero muncie bellhousing, I guess the allante will clear it right??
Raydar, by the way I'm not stalking you LOL
just want to get my 4.9 fiero running and you seem to be a reliable source of information
regards
Pedro
manriquez
Report this Post05-26-2016 10:56 AM Click Here to See the Profile for manriquezSend a Private Message to manriquezEdit/Delete MessageReply w/QuoteDirect Link to This Post
manriquez
Member since Apr 2015
zmcdonal
Report this Post05-26-2016 11:01 AM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup. Those are what the Allante starters look like.
manriquez
Report this Post05-26-2016 11:12 AM Click Here to See the Profile for manriquezSend a Private Message to manriquezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks!
Report this Post05-26-2016 11:39 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
GM starter bolts are Dorman and likely other catalogs.
Total ratings: 461
Report this Post05-26-2016 06:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pedro... I'm happy to help. The ebay starter looks just like mine.
The wiring is a direct replacement. I may have had to extend one of the wires, or at least remove some of the wrapping, but it wasn't a big deal.
Otherwise it bolts right up. Weighs less than half of what the original starter weighs.
Mine has been in the car for quite a few years. No problems whatsoever.
Report this Post05-26-2016 09:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I get starters and alternators at AZ w/ lifetime warranty and good at any locations.
As long as you remember phone # at time of sale, Warranty will be honored very easy. I've return a 10+ year old starter under AZ warranty.
Heat shield is easy. Any sheet metal can be used to make them. Just make sure new shield can't cut cable insulation etc. The battery can easily dump 200+ amps into a short circuit.
[This message has been edited by theogre (edited 05-26-2016).]
zmcdonal
Report this Post05-26-2016 09:38 PM Click Here to See the Profile for zmcdonalSend a Private Message to zmcdonalEdit/Delete MessageReply w/QuoteDirect Link to This Post
I quit buying anything electrical from autozone. When they warranty out a failed part and give you a refurbished one, they only fix what has failed in that alternator or starter. Sure, they'll replace it but my time and hassle is worth something too and I'd like for my vehicle to be more reliable than that.
