  Where or who can I get a custom 4.9 ecm chip from?
Where or who can I get a custom 4.9 ecm chip from? by flyntus
Started on: 09-23-2015 09:46 AM
Replies: 5 (472 views)
Last post by: Dennis LaGrua on 09-23-2015 04:08 PM
flyntus
Report this Post09-23-2015 09:46 AM Click Here to See the Profile for flyntusSend a Private Message to flyntusEdit/Delete MessageReply w/QuoteDirect Link to This Post
Need ecm chip for "85 Pontiac Fiero, 4.9, 4-spd, AC.
Total ratings: 154
Report this Post09-23-2015 09:54 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe try Sinister Performance. www.gmtuners.com
flyntus
Report this Post09-23-2015 10:01 AM Click Here to See the Profile for flyntusSend a Private Message to flyntusEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks will contact them!
hnthomps
Total ratings: 51
Report this Post09-23-2015 10:32 AM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero Factory in Toney, AL might also be a source since they do 4.9 conversions in Fieros.
Nelson
Total ratings: 207
Report this Post09-23-2015 01:00 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also check with Forum member stickpony.
Total ratings: 328
Report this Post09-23-2015 04:08 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4.9L ECM uses what is known as a Memcal unit. The chip is permanently soldered into this unit. You can purchase a plug in Memcal adapter from Craig Moates that will allow you to easily remove and replace the chip. Some programmers try to erase and re-program the chip while it is in the Memcal unit and this can work, but IMO reprogramming 20+ yr old electronic chips is not a good idea. When I program I always use fresh brand new chips. The 4.9L uses a generic 27C512 eprom and its still available as is the flash based memory version with the same configuration as 27FS512. The electronically erasable memory is faster and easier to work with. .
[This message has been edited by Dennis LaGrua (edited 09-23-2015).]
