If you mean on the 87-88 intake, I think you'd need to use a dremel tool to sand/polish inside the engraving. If you mean the 85-86 intake, you'd need to sand/polish the top flat section, and apply a new decal.
I just sanded my down and it looked like new. Thought about clear-coating after the fact. I'll post a pic if one is handy.
Spoon
Is the 87 different from the 86 I was going to buy one here in the forum and its off an 87 and mine is an 86 was only going to but the upper intake???????? Thanks, Randy
Can these be Vatted and cleaned and then be repainted ????????
Sure can. I have the engraved type and I striped it down with "Aircraft Paint Remover". The powder coat just wrinkled and I hosed it off down to the aluminum. Repainted it traditional Pontiac blue and painted the engraved area in red.
I gotta find a pic to post.
Spoon
[This message has been edited by Spoon (edited 09-11-2015).]
I have done both of mine, both are 88's with the engraved Fiero. 87 and 88 intakes both were engraved. 85 and 86 had the sticker. Using aircraft stripper is the best way to remove the old coating. I used a good self etching primer and VHTcaliper red. Very close red to stock. Then clear coat. One o did two years ago and the other just recently. I carefully scaped the aluminum part off with a razor scraper and the sanded it smooth. It make take a few times with stripper to get all off. I had to strips some spots 4 or 5 times. Cheapest and easiest way to strip them. Best of luck Hope this helps Brian
I know we're talking intakes here... but these were the nicest refinished valve covers I'd ever seen. (Saw them in the Mall.) Look at that shine on the polished parts!
There's no real difference internally between the 85-86 and 87-88 upper plenums. The main difference is the 87-88 have the engraved Fiero and the 85-86 have the sticker.
I've refinished a number of plenum and valve cover sets. Aircraft Stripper is a good product for removing the old paint. I also used a 3M Scotchbrite wheel on an arbor with my power drill to work down in the recesses. Multiple applications of stripper were required.
After getting them totally stripped, I washed them down with a good degreaser and when they were dry, I washed them with white vinegar. Once they were dry from the rinse, I used Zinc Chromate primer and let it sun cure for a day. The next day I oversprayed that with Dupli-Color DE1605 Ford Red High Temperature Ceramic Engine Paint.
Another day of curing in the sun then using a single edge razor blade style glass scraper, I shaved the paint off the areas that were to be polished. Just place the blade on 2 ribs at a 45 degree angle and push. You can get most of the paint and primer off the areas you intend to polish.
The next step, in order to keep the paint from peeling away at the sharp edges is to tip the razor blade at a 45 degree angle and push it along the edges. I then used a pad sander and I think I started with about 200-400 grit sand paper. This will cut the remaining paint and primer stain from the polished areas. Work your way up to 800-1000 grit for a good polish.
The color is a little off compared to original Fiero red, at this point, but the next step brings it much closer. So that you don't get the nice red intake and valve covers stained with blood, be sure the significant other is away from the house for the next 3 or 4 hours. Preheat the electric oven to 250 degrees. Insert the painted parts and bake for 30 minutes. Let cool and serve on a Fiero engine. This will give you about the same finish as the original but won't protect the polished areas from discoloration. Clear coating would be in order. I've never clear coated so I can't make a recommendation on which product to use, but if it's high temp, I'd recommend doing it before baking in order to get a good bond between color and clear.
This is a picture of my engine taken about a year ago. It had about 12,000 miles on it at the time.
My former 86 SE that I gave away, I shined up my upper plenum and valve covers just like Patrick showed. I should mention most of these don't really ever need repainting because the original powder coated finish shines up if your careful with the buffing wheel attached to a bench grinder used with the grey aluminum polishing stick you find near the welding section at Harbor Freight. Powder coating in the Fiero is one of the things that GM did correctly.
I like the raw finish!!! Wish I would have done one of mine that way!!!! Almost did. Now that I see the pics, looks sweet.....makes me jealous!!!!! Very nice job!!!!!
when I did my isuzu trooper I cleaned the valve covers with good cleaner and pressure washer. then used aircraft stripper to remove all old power coating that gm did, get them completely clean and then shoot them with red (or what ever) paint you want. let dry and i baked in wifes oven. (dont ask about her suprise) then after a few days I took some fine sandpaper on a flat wood block and started sanding the raised area down to bare aluminum. then cleared over top. it lasted three years with no chipping peeling and then i sold it so not sure about after 3 years.
