Just tuned up (tried) my V6 with new plugs, wires, ICM, pickup coil and new O-ring on the distributor. Put everything together, proper firing order, noted the position of the rotor, and tried to start but no dice. Rotated distributor slightly and it will catch weakly and run for a few seconds like it's only on 2 cylinders. I thought I'd learned my lesson on changing wires before... but this one has me stumped. Any advice?
------------------ My Fiero: 1986 Pontiac Fiero GT, V6, 4-speed manual
It does sound like a timing problem. Did you note the position of the rotor before or after lifting it up? Hopefully both.
Also, did you note the position of the gear relative to the rotor when replacing the pickup coil? I'm not a hundred percent certain this makes a difference. I think I forgot so maybe I was lucky.
Hopefully you didn't crush the pickup coil wires when replacing the cap - happens to the best of them. My new distributor came that way.
You could try putting a bulb or timing light on the number one plug wire to see if the timing mark ends up somewhere near the window when it fires. This is essentially setting the timing. If the mark is nowhere near the window when the plug fires try bumping the starter until the line is near the window, then take the cap off to see where the rotor is. If it points opposite where your number one plug wire should be the easiest thing to do would be to rearrange the wires so they do line up. The best thing to do would be to lift the rotor and put it back so it does line up with the number one wire when the timing mark is near the window.
Do you have pictures of your distributor with the cap on and off? Sometimes a PO got it to work in a peculiar way. If so, now would be a good time to set it straight. Check some images on the forum or elsewhere online to see if your setup looks like the majority.
I just got it to start. Turned out to be timing, and it was just a bit off. It's backfiring a bit, so I need to time it properly but at least I got it started.
It's not unusual for a new rotor to need some persuasion to seat all the way down. For this a rubber mallet and restraint can be useful.
It's also not unusual for there to be too much play in the vertical movement of the distributor shaft. For this you need shim washers (hard to find) or a hardware store washer ground down if necessary. Watch your cap when it's running. It shouldn't be jumping or moving.
The sequence is right, but for some reason the orientation of my distributor doesn't match that picture. My #1 wire post is where the #2 post is on there, slightly rotated.
In theory you could rotate the distributor, but it probably won't move that far given the length of the connector wires and the limited space. I think I've ended up moving all the wires on two different Fiero V-6 engines. Just take one off, move one up, and work your way around. This engine has such a simple and convenient firing order it might be easier to take them all off and reroute them one at a time. Have you by any chance already done this? Are you driving now?
