  and now a question for the Northstar throttle body swappers
and now a question for the Northstar throttle body swappers by Dave E Bouy
Started on: 08-27-2015 09:03 AM
Replies: 4 (418 views)
Last post by: Ryanap333 on 08-29-2015 07:26 PM
Dave E Bouy
Report this Post08-27-2015 09:03 AM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am installing a 2000 Northstar throttle body and MAF on a gen v supercharger and have 2 questions about wiring.
1st. I have the TPS connector and the colors are the same as any other GM TPS I've ever seen, blue, grey, black, should I assume I can connect blue wire to blue wire, grey wire to grey wire etc.
2nd. Does anyone have a pinout for the 2000 Northstar MAF/IAT.
Thanks
DF
Total ratings: 291
Report this Post08-27-2015 05:09 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dave E Bouy
Report this Post08-27-2015 06:56 PM Click Here to See the Profile for Dave E BouySend a Private Message to Dave E BouyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Tim, that answers #2, anyone know about the TPS?
Total ratings: 328
Report this Post08-27-2015 07:41 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
DF
Irrespective of the pin-out, realize that the N* MAF table values must be imported into the 3800 program for proper fueling. I didn't use a N* MAF because the tables were hard to find. I used the LS1 75mm MAF as the table is readily available as is the LQ4 table. With the N* TB and N* MAF the flow changes and you must be prepared to tune the MAF values. It wasn't hard to do with the LS1 MAF but before the change I was running very lean at the lower frequencies of the curve.
At cruise conditions the 3800 flows less air than a N* at the same RPM and therefore on the lower end of the MAF curve the fueling becomes leaner. At the higher rpms the 3800SC flows more air and that pushes the flow rate into the higher MAF frequencies and you can run richer. Point is that if you go larger on the TB and/or MAF, you will need to tune, preferably with a wideband O2 sensor.
Ryanap333
Report this Post08-29-2015 07:26 PM Click Here to See the Profile for Ryanap333Send a Private Message to Ryanap333Edit/Delete MessageReply w/QuoteDirect Link to This Post
Timm/phonedawgs if you read this please contact me asap in regards to my harness and computer...
