Update System
  2.8 almost dies when coasting, ideas?
2.8 almost dies when coasting, ideas? by countach711
Started on: 07-20-2015 11:47 PM
Replies: 3 (110 views)
Last post by: countach711 on 07-21-2015 02:42 PM
countach711
Report this Post07-20-2015 11:47 PM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have a turboed 2.8 4-speed that I've replaced practically all sensors, fuel pump, filter and injectors, etc. It runs much better than when I got it, mainly due to the injectors, but now it almost dies when coasting not under load. It will come back to life when I hit the gas with a bit of a jerk. No PCV valve, no vacuum leaks, MAP sensor tested okay. I did some research and saw TPS as a possible cause, idle adjustment screw, and someone solved a similar issue because there was too much teflon tape on his temperature switch (needs to be grounded). Any other opinions or ideas of what to look for?
f85gtron
Report this Post07-21-2015 05:37 AM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
Timing or iac valve.
Clean the iac passages. The iac is responsible for idle. Usually only comes into play at around 4mph or under and no throttle.
Check timing.
Report this Post07-21-2015 12:24 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The VSS sends a signal to the computer to tell the engine how to idle between shifts and coasting in neutral. Is your ECM original, and for a stick shift?
countach711
Report this Post07-21-2015 02:42 PM Click Here to See the Profile for countach711Click Here to visit countach711's HomePageSend a Private Message to countach711Edit/Delete MessageReply w/QuoteDirect Link to This Post
good question. I have the original builder's phone number so I will call him and ask if he knows.
