  "Value Fiero" vs SE/Indy
"Value Fiero" vs SE/Indy by rkirkpatrick
Started on: 07-18-2015 10:03 PM
Replies: 7 (340 views)
Last post by: Raydar on 07-21-2015 06:17 AM
rkirkpatrick
Report this Post07-18-2015 10:03 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a 86 2.5 duke. I think it is a "value" fiero as opposed to a SE.
I have no power window, locks or mirrors. I am guessing this is the Value package...fine with me...
Are other parts from SE notch backs interchangeable with mine?
Just getting started, so sorry for stupid questions
Report this Post07-18-2015 10:08 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
In 1986 there was an option package called 'value leader'. It's code is WV9. You should find that code on the option sticker on the left wheel well liner under the hood, and Yes, just about everything on any Fiero fits on any other Fiero.
Welcome to the Forum!
[This message has been edited by Gall757 (edited 07-18-2015).]
rkirkpatrick
Report this Post07-18-2015 10:22 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks
Total ratings: 463
Report this Post07-20-2015 06:00 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The only things that are not interchangeable with yours are some 84 parts (doors/door skins, and anything having to do with wiring) and 88 brake and suspension parts. 87s and 88s also got different headlight motors and wiring, and different gas tanks. The 87-88 four cylinder engines are different enough to not be a direct bolt-in.
Other than that, most everything is fair game. Enjoy.
And welcome to our obsession!
Praise the Lowered!
rkirkpatrick
Report this Post07-20-2015 09:57 AM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
so an 84 duke should slide in the place of an 86 duke??
Thanks for info
86 5 speed 2.5 Iron Duke
TopNotch
Total ratings: 60
Report this Post07-20-2015 02:14 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 86 "Value leader" Fiero had black bumper pads on the front and rear of the car.The 86 SE had an "aero package" that included a more aerodynamic nose and side skirts.
While you could put an 84 duke into an 86 car, you probably wouldn't want to, because the 84 duke had flat lifters, while the 86 duke had roller lifters. Also, 84 was the year that some of the dukes had bad rods.
rkirkpatrick
Report this Post07-20-2015 08:49 PM Click Here to See the Profile for rkirkpatrickSend a Private Message to rkirkpatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the help...
I have enough info not to buy the donor 84...not enough good parts to use to over ride the anger I will receive from the wife
Total ratings: 463
Report this Post07-21-2015 06:17 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
That sounds about right.
Good luck with your project.
