  repair kit AC ?
repair kit AC ? by Lou6t4gto
Started on: 07-13-2015 12:01 AM
Replies: 2 (241 views)
Last post by: Lou6t4gto on 07-13-2015 01:13 PM
Lou6t4gto
Report this Post07-13-2015 12:01 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
is there some kind of "repair kit" (like they have for an evaporator core) to replace the end of the Large" main line" going to the Drier from the back of the car. Someone tried to clip it off with a bolt cutter !
steve308
Total ratings: 58
Report this Post07-13-2015 08:41 AM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Need a little info ---- Is it the fitting that was cut or the line itself? If it is a hard line it needs to be flared on both ends and then a piece of AC barrier refrigerant hose can be installed and clamped on using a clamp like this ----
DormanĀ® 800-670 - Line Splice Kit for 5/8" Line With #10 Hose
If it is a clean cut in the barrier hose a section of tubing with clamps on both ends can work -- do not use a repair tube like on a regular garden hose as the barbs will cut into the barrier hose causing it to leak. Both of these can work but it's a band-aid repair.
If it's the fitting at either end, take the line off, purchase a replacement end and have a hydraulic line shop crimp them on.
You can have new lines made, not cheap, but these lines are 20+ years old and prone to refrigerant 'seepage' and made for a now discontinued refrigerant. Do it right the first time - you will be glad you did.
[This message has been edited by steve308 (edited 07-13-2015).]
Lou6t4gto
Report this Post07-13-2015 01:13 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Someone used a "Bolt Cutter" ( about 4 inches from the fitting) it's cut about 90% off. WHY someone would DO such a thing is beyond me ! I used a tubing cutter and removed the Line about 6" from the fitting. will cut off the crushed part, and try the soft line and clamp approach.
