  Timing gears-so far so good
Timing gears-so far so good by wheelhorse
Started on: 07-11-2015 06:43 PM
Replies: 6 (141 views)
Last post by: jaskispyder on 07-11-2015 08:46 PM
wheelhorse
Report this Post07-11-2015 06:43 PM Click Here to See the Profile for wheelhorseSend a Private Message to wheelhorseEdit/Delete MessageReply w/QuoteDirect Link to This Post
[img]<a href="http://s1157.photobucket.com/user/wheelhorse2347/media/Mobile%20Uploads/CAM00516.jpg.html" target="_blank"><img src="https://images.fiero.nl/photobucket/albums/p593/wheelhorse2347/Mobile%20Uploads/CAM00516.jpg" border="0" alt=" photo CAM00516.jpg"/></a>[/img]
Well, I was able to make it this far only removing the passenger wheel, crank pully, some water jacket cover thing and the timing cover.
I suspect from all my reading that was the easy part. It almost looks like Id have enough room to get in with a torch and a puller but would this be ill advised? I dont have any engine hoist and would prefer to disturb as little of the electronics and vacuum hoses as possible. Before the gear went, it was running fantastic.
Of course, if I must pull the whole cam, I have to do what I have to do.
Any idea why gm chose the press on as oppossed to a bolt on hub? Was it to make the shops money ? This would be an easy job if that were the case.
wheelhorse
Report this Post07-11-2015 06:45 PM Click Here to See the Profile for wheelhorseSend a Private Message to wheelhorseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Slammed
Total ratings: 79
Report this Post07-11-2015 07:02 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
Air hammer and chisel the gear off. You can use a die grinder or dremel but it will take longer. Then, take a propane torch and heat up the hub of the new gear for 90 seconds. It will expand enough to slide the new gear on the end of the cam. You gotta do it fast, like 5 seconds fast
I've done it exactly like this a dozen times
[This message has been edited by Slammed (edited 07-11-2015).]
wheelhorse
Report this Post07-11-2015 07:11 PM Click Here to See the Profile for wheelhorseSend a Private Message to wheelhorseEdit/Delete MessageReply w/QuoteDirect Link to This Post
Excellent. That is simmilar to what I had in mind though I was going to drill and tap the gear, then use a timing gear puller to get it off, then heat oil in the dutch oven to heat the gear. think pulling it cold would cause damage to the shaft? I imagine you only got one shot to get the new one on then (cue Eminem-lose yourself).
It might be worth the investment for an air hammer then. In honesty, I dont think I can get a drill in tthat space anyway.
Ill probably have to wait a week or two, but cant wait too long. Its on a slab IN The back yard
wheelhorse
Report this Post07-11-2015 07:17 PM Click Here to See the Profile for wheelhorseSend a Private Message to wheelhorseEdit/Delete MessageReply w/QuoteDirect Link to This Post
wheelhorse
Member since Jan 2015
How how easily does the gear shatter?
Slammed
Total ratings: 79
Report this Post07-11-2015 08:06 PM Click Here to See the Profile for SlammedSend a Private Message to SlammedEdit/Delete MessageReply w/QuoteDirect Link to This Post
The gear breaks easily, it's the metal hub that is hard to get off
There isn't enough room for a puller without tilting the cradle down. If the gear gets stuck halfway while putting it back on, heat around the hub and pull it back off. Where a glove, that thing will be hot
jaskispyder
Total ratings: 205
Report this Post07-11-2015 08:46 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
