  IS IT POSSIBLE ? GMTuners charts
IS IT POSSIBLE ? GMTuners charts by Lou6t4gto
Started on: 07-09-2015 05:50 PM
Replies: 1 (174 views)
Last post by: Darth Fiero on 07-09-2015 06:04 PM
Lou6t4gto
Report this Post07-09-2015 05:50 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
on these charts, http://www.gmtuners.com/fil...o_L67_PCM_wiring.pdf * Is there a way to get these to PRINT OUT LARGER ???? no matter what we do, it always prints out so small it cannot be easily Read. CAN it be ENLARGED ? can it be changed from a PDF file to something that Can be Enlarged ?
If we were able to enlarge this thing to poster size and hang it on the wall , it would be light years better ! Thanks
Darth Fiero
Total ratings: 361
Report this Post07-09-2015 06:04 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes there is.
1) Open the wiring diagram .pdf.
2) Click File>Print.
3) In the pop-up print window, there should be a header halfway down named "Page Sizing and Handling". Under that header, there should be a selection button for "Poster" - click this. Below this, there should be a place you can input a different size "Tile Scale" to enlarge the poster size. Default is 100%.
In the window to the right of these selections there should be a preview window that will show you how many pieces of paper will be used and how the printout will appear on those pieces of paper.
More is more. Less is not enough.
