  wheels & tires?
wheels & tires? by jmdcoolNE07
Started on: 07-09-2015 01:41 PM
Replies: 4 (201 views)
Last post by: Raydar on 07-10-2015 06:46 PM
jmdcoolNE07
Report this Post07-09-2015 01:41 PM Click Here to See the Profile for jmdcoolNE07Send a Private Message to jmdcoolNE07Edit/Delete MessageReply w/QuoteDirect Link to This Post
Would wheels and tires specified for 1988 fiero GT fit on the 1985 GT? without mods?
Ramon
Report this Post07-09-2015 02:12 PM Click Here to See the Profile for RamonSend a Private Message to RamonEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 85 came with
185/80R13 front/ rear
195/70R14 front/rear
215/60R14 front/rear
The 88 came with
185/75R14 front
195/70R14 rear
205/60R15 front
215/60R15 rear
All of them have the same offset 14" and 15" not sure about 13.
15x6" +37mm offset front wheel
15x7" +30mm offset rear wheel
Maybe some one else can confirm this but I pretty sure they will fit fine.
[This message has been edited by Ramon (edited 07-10-2015).]
hnthomps
Total ratings: 50
Report this Post07-10-2015 02:56 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 88 vehicles use offsets than the earlier vehicles. I have seen 88 rims installed on earlier vehicles but they may or may not look a bit strange (everyone has a specific personal preference). They will certainly fit on the wheel lugs but the offsets may not be correct.
Nelson
Report this Post07-10-2015 06:15 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rear wheel offset is the same on all Fieros.
Total ratings: 463
Report this Post07-10-2015 06:46 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
They'll fit.
The 15x7 88 rear wheels are essentially the same casting as the earlier 15x7 wheels, except that they are painted different colors, and the valve stem is drilled in a different place. I have measured the offsets of both wheels. They are identical in that regard.
The 15x6 88 front wheel is essentially the same wheel, minus the 1" lip on the front face.
I have seen a set of 88 wheels mounted on an earlier car. They fit fine. The fronts look a little bit "tucked in" under the front, compared to the regular wheels, but there were no interference issues at all. The real advantage to using those wheels is that the steering should be a good bit lighter, due to the decreased scrub radius.
Praise the Lowered!
[This message has been edited by Raydar (edited 07-11-2015).]
