  3800 + a/c bypass
3800 + a/c bypass by Tuna Helper
Started on: 07-07-2015 01:34 PM
Replies: 0 (114 views)
Last post by: Tuna Helper on 07-07-2015 01:34 PM
Tuna Helper
Report this Post07-07-2015 01:34 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
Due to my choice of exhaust in my 3800sc swap, I have to run an a/c bypass pulley. Now that it is in, I can't get the belt back on. I took the pulley off and measured, it is about a quarter inch larger diameter than the a/c compressor. It's supposed to use the same accessory belt, but doesn't. Google is failing me in a search for a belt number, so I am asking here, if anyone has run into this and knows a good belt number or an application? I found this " '88 2.8L Corsica without A/C" But I don't know if that is really what I need? (supposedly you can just buy a shorter belt and skip the bypass pulley altogether, but then you have to change some pulleys or something else.
:edit:
The difference in circumference is roughly an inch. (0.981") Seems to me that isn't a lot, but it's enough to keep the belt from going on. If the belt length on AutoZone is right, (2379.98 mm) then adding 25.4 mm brings me to 2405.38 mm, and this is the closest I have found so far. http://www.beltpalace.com/6pk2410.html If I put 6pk2410 in the auto zone search, I get a hit. http://www.autozone.com/coo...yco-belt/150407_0_0/ I
[This message has been edited by Tuna Helper (edited 07-07-2015).]
