  3800sc swap temp gauge pegging and now stuck
3800sc swap temp gauge pegging and now stuck by vette7584
Started on: 07-05-2015 09:15 PM
Replies: 3 (87 views)
Last post by: IanT720 on 07-06-2015 05:50 PM
vette7584
Report this Post07-05-2015 09:15 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
3800sc swap. temp gauge pegs to right, now stuck, i can open bezel and move back, but how do i keep this from happening again? also, speedo quit working, needle doesnt move, but trip odometer works, any ideas? thanks
vette7584
Report this Post07-06-2015 05:35 AM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
do i swap wires around like it says in some of the threads? will that work with the 3800 conversion?
Total ratings: 205
Report this Post07-06-2015 07:58 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Easy fix to temp gage - ignition switch on top of column.
One terminal has two light green wires.
Cut the wires and connect them together and insulate.
This will eliminate the pegging at key ON/BULB TEST/START
Insulate the cut wires from the switch to prevent shorts.
Joe
IanT720
Report this Post07-06-2015 05:50 PM Click Here to See the Profile for IanT720Send a Private Message to IanT720Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you use the 88 Fiero oil pressure sensor? You have to. Also make sure you don't bend the pins when installing the connector. I did and it was pegged.
1987 Fiero GTX 3800 Turbo... My Build, ST3 Cam, Lowered, Wheels, and pics enjoy!https://www.fiero.nl/forum/Forum1/HTML/089483.html
