  outer door handle spring
outer door handle spring by commerce
Started on: 07-05-2015 05:58 PM
Replies: 4 (171 views)
Last post by: Patrick on 07-20-2015 12:56 AM
commerce
Report this Post07-05-2015 05:58 PM Click Here to See the Profile for commerceSend a Private Message to commerceEdit/Delete MessageReply w/QuoteDirect Link to This Post
The spring that retracts the outer door handle has come loose.
Does the handle have to come off to reset the spring?
Thanks for any help.
imacflier
Report this Post07-05-2015 08:24 PM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
Commerce,
I hope you get a great answer, cause my handle is loose as hell, too. The best I could find in search is: https://www.fiero.nl/forum/A...130314-2-118747.html
Good luck and post how you finally do it!
Larry
Report this Post07-07-2015 12:08 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The good news is that you have two ways of dealing with this.
The bad news is that you either need to remove the outer door skin... or the interior panel.
But yes, the door handle needs to come off. I suggest you do it from the inside.
[This message has been edited by Patrick (edited 07-07-2015).]
commerce
Report this Post07-20-2015 12:35 AM Click Here to See the Profile for commerceSend a Private Message to commerceEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did have to remove the outer door skin. Which isn't that difficult as long as those torx bolts (or whatever they are) cooperate.
The door handle seems to be some sort of cast metal. The clips which hold the return spring in place are cast into the handle. They had broke off on one end and left the spring loose. There was enough of the clip left to reattach the spring by bending it over the spring. It works fine for now, but will probably new one.
Report this Post07-20-2015 12:56 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's one way of removing the outside door handle, but it's not absolutely necessary. The handle can also be unbolted from inside the door.
