  1987 FIERO GT STARTS HARD WHEN COLD
1987 FIERO GT STARTS HARD WHEN COLD by fierogtguy1
Started on: 07-04-2015 08:11 PM
Replies: 3 (224 views)
Last post by: fierosound on 07-05-2015 07:18 PM
fierogtguy1
Report this Post07-04-2015 08:11 PM Click Here to See the Profile for fierogtguy1Send a Private Message to fierogtguy1Edit/Delete MessageReply w/QuoteDirect Link to This Post
MY 87 GT STARTS HARD WHEN COLD BUT ONCE STARTED, IT WILL START RIGHT UP WITH NO ISSUES UNLESS IT SITS A FEW HOURS. WHY AND HOW TO REPAIR?
THANKS.
Hudini
Total ratings: 165
Report this Post07-05-2015 05:37 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your fuel pressure while running and then watch it as you shut off the engine. You should have near full pressure for a good 10-15 minutes then it will slowly bleed down but should never go to zero. If the pressure drops to zero as soon as the engine is shut off then suspect the fuel pressure regulator. It's also possible the check valve in the fuel pump is bad but that is much less common.
Lou6t4gto
Report this Post07-05-2015 12:29 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
the 2.8 has a Cold start injector located at the End of the intake manifold and a cold start Switch on top of the intake. Usually it will be the cold start SWITCH that goes bad.
fierosound
Total ratings: 286
Report this Post07-05-2015 07:18 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by fierogtguy1:
MY 87 GT STARTS HARD WHEN COLD.....
THANKS.
Find the CAPS LOCK key on the keyboard and use it to turn it OFF.
Thanks...
