  4.9 93 ECM with reserve for 2nd O2 sensor
4.9 93 ECM with reserve for 2nd O2 sensor by falcon_ca
Started on: 06-28-2015 09:54 PM
Replies: 1 (202 views)
Last post by: phonedawgz on 06-28-2015 10:21 PM
falcon_ca
Report this Post06-28-2015 09:54 PM Click Here to See the Profile for falcon_caSend a Private Message to falcon_caEdit/Delete MessageReply w/QuoteDirect Link to This Post
I found that the ECM in my car have reserve for 2nd O2 sensor. No error code.
I only have one installed, no provision yet for a second one.
Should I have the signal from the O2 sent to both inputs ?
"I'm not driving too fast, . . . I'm just flying too low."
Work done 07-08 | Work done 08-09 | Work done 09-10 | Work done 10-11 | Work done 11-12 | Work done 12-13 |Work done 13-14 | 4.9 Swap |Parts for sale
Total ratings: 290
Report this Post06-28-2015 10:21 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you are not getting an error code with the second disconnected, then the PCM is programmed to ignore it.
