  What do most use to silence the noise in this area.
What do most use to silence the noise in this area. by solotwo
Started on: 06-27-2015 03:34 PM
Replies: 12 (368 views)
Last post by: solotwo on 06-30-2015 10:41 PM
solotwo
Total ratings: 62
Report this Post06-27-2015 03:34 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I never noticed how much noise comes through this area around the connectors.
Spoon
Total ratings: 61
Report this Post06-27-2015 05:18 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
There's insulation on the other side of the bulkhead plus the ECM is surrounded by the rear console compartment with plenty of insulation in there. I've never noticed any objectionable sounds. Maybe someone with a better set of ears than mine will chime in later.
Spoon
Neils88
Total ratings: 56
Report this Post06-27-2015 05:58 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
The noise will probably go away once you put the storage bin back in place.
solotwo
Total ratings: 62
Report this Post06-27-2015 07:34 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks. I am going to try a little foam.
Report this Post06-27-2015 10:41 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pull the ECM to see if the transmission cable grommets are still in place. Lots of heat and noise can enter if they aren't securely installed.
ltlfrari
Total ratings: 127
Report this Post06-27-2015 11:30 PM Click Here to See the Profile for ltlfrariClick Here to visit ltlfrari's HomePageSend a Private Message to ltlfrariEdit/Delete MessageReply w/QuoteDirect Link to This Post
Careful on the foam, the ecm needs some airflow around it for cooling.
Dave
www.ltlfrari.com
Report this Post06-27-2015 11:51 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wires are sealed by "re-entry encapsulation/potting" compound that removable by hot water I think.
Closest thing available and cheap to that for public is maybe Latex Interior caulk.
should not permanent glue the plastic in case you need to remove it later.
also See my Cave, ECM Heat
Entire case must have plenty of air because ECM/PCMs will die w/o enough air to dump heat.
solotwo
Total ratings: 62
Report this Post06-28-2015 09:28 AM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the information. I am not removing them. I just noticed with console off to address a different situation that it was very noisy and you can see daylight when looking out into the engine compartment. So I was looking for ideas to "seal" the area up from engine noises.
Riddick85
Report this Post06-28-2015 11:13 AM Click Here to See the Profile for Riddick85Send a Private Message to Riddick85Edit/Delete MessageReply w/QuoteDirect Link to This Post
In my opinion the noise is good. When you want it quiet have the console on but if you are listening for a problem, you can more easily hear it with it off. Used that to my advantage a few times
solotwo
Total ratings: 62
Report this Post06-28-2015 12:20 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
The exhaust on this car is loud to the point of unbearable. Thats next after i get the trans issue figured out.
Report this Post06-28-2015 03:43 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
There really shouldn't be any openings into the engine bay. Pressure from air flowing up into the engine bay can bring exhaust gases into the passenger compartment. I discovered this when work was done on one of my Fieros and the transmission cable grommets weren't properly reinstalled.
Neils88
Total ratings: 56
Report this Post06-28-2015 03:47 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
Where exactly do you see light from the engine compartment? Through the wire bundles? If so, you'll definitely want to seal the wire bundles using a latex caulking as mentioned by Ogre.
solotwo
Total ratings: 62
Report this Post06-30-2015 10:41 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I used chalk I think it is silicone. Any the plug that was redone for the swap had the "holes".
