  Brake booster or master cylinder
Brake booster or master cylinder by Wittendorf1986
Started on: 06-26-2015 01:41 AM
Replies: 2 (557 views)
Last post by: theogre on 06-26-2015 10:56 AM
Wittendorf1986
Report this Post06-26-2015 01:41 AM Click Here to See the Profile for Wittendorf1986Send a Private Message to Wittendorf1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to know more bout the brakes on a fiero, now I have replaced everything you can about replace on the the brake system bled several times but I am having trouble with my brakes and my idle. While my car is running I hit the brakes while in park everything is fine but I put it in reverse I do hear a whooshing sound but here is the thing my pedal goes to the floor. But I will pump it a few times I will gain some pressure but I wait a few seconds it is gone again low pedal. I put car in drive or reverse hit the brakes it acts if it is going to die. I don't understand wouldn't it have a high pedal and hard to press if booster is bad? I replaced it last year along with my master cylinder
Report this Post06-26-2015 09:03 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
There still is air in the brake system. The idle is a separate issue.
[This message has been edited by Gall757 (edited 06-26-2015).]
Report this Post06-26-2015 10:56 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Booster will not cause hydraulic problems, your pedal to floor. Air you hear is likely normal as booster is just trying to do it's job on a low/no pedal problem.
