  Flexible Stainless Steel Hose - what size should I get ?
Flexible Stainless Steel Hose - what size should I get ? by PaulJK
Started on: 06-22-2015 08:55 PM
Replies: 1 (116 views)
Last post by: PaulJK on 06-24-2015 05:48 PM
PaulJK
Total ratings: 237
Report this Post06-22-2015 08:55 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm gonna try to upgrade my cooling system by using flexible stainless steel hose. i think i wanna use 2 pieces on the radiator and 2 pieces on the rear connecting the coolant tubes to the engine. The engine is a 1999 3800sc with auto trans. I want to know 2 things:
1. what size / diameter flex hose should i get ( 1 and 1/4 ?)
2. What length should i get for the rear connections to the engine ? i think i read somewhere the passenger's side connection to the engine is 18 inches and the driver's side connection to the engine is 36 inches.
By the way, i'm planning to use a champion 3 core aluminum radiator which i think still uses the green coolant.
Thank you.
PaulJK
Total ratings: 237
Report this Post06-24-2015 05:48 PM Click Here to See the Profile for PaulJKSend a Private Message to PaulJKEdit/Delete MessageReply w/QuoteDirect Link to This Post
