  waterpump pulley have to be flush with other pulleys or is it off a bit
waterpump pulley have to be flush with other pulleys or is it off a bit by AL
Started on: 06-22-2015 12:01 PM
Replies: 2 (137 views)
Last post by: AL on 06-23-2015 12:23 AM
AL
Report this Post06-22-2015 12:01 PM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
As title saids I changed pump and pulley but now that it is on it looks a little of from the bottom pulley,anyone can help with a pic, please.
Blacktree
Total ratings: 350
Report this Post06-22-2015 12:33 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can check by laying a straight flat object (like a level or a long ruler, or a straight piece of lumber) across the faces of the pulleys. If it lays flat across the pulleys, you're good to go. If it's sitting at an angle, you have a problem. Pulleys that are misaligned can damage the belt, or cause it to come off.
AL
Report this Post06-23-2015 12:23 AM Click Here to See the Profile for ALSend a Private Message to ALEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info,I decided to take it to a shop so they could install the pulley properly On the waterpump.
