  timing chain cover gasket question
timing chain cover gasket question by NCTyphoonKid
Started on: 06-15-2015 08:12 PM
Replies: 5 (257 views)
Last post by: NCTyphoonKid on 06-17-2015 10:03 PM
NCTyphoonKid
Report this Post06-15-2015 08:12 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would I be better off with a paper gasket or a gasket maker sealant. I put the paper gasket on a couple years ago and it started leaking around the water jacket so I finally figured out where the leak was coming from and why it kept overheating.
Korey "Plastic Makes It Possible"
86 Pontiac Fiero SE #70123, gold on black options incl luggage rack,power windows,power door locks,sunroof,4 spd,black GT lace wheels,restoring it back to stock check out my build thread!
84 Jeep CJ7 "Dixie"
86 Buick Grand National bone stock
93 GMC Typhoon #1710 black on black bone stock
fieromatty
Report this Post06-15-2015 11:55 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I honestly would use both. Put a thin layer of gasket sealer on each side of the paper gasket and apply it. I have never had any trouble with this method.
NCTyphoonKid
Report this Post06-16-2015 06:28 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the advice this is how I done it this time. How long do you think I should wait to put antifreeze back in it and see if it has any leaks this time? I've already bolted the cover back to the engine but haven't installed the harmonic balancer or water pump pulley or any hoses
fieromatty
Report this Post06-16-2015 09:15 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
24 hours. You can fill the system, but i wouldn't run it till then.
Hudini
Total ratings: 165
Report this Post06-17-2015 03:29 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Permatex #2 sealant on both sides of the gasket and you can fill it and start it immediately.
NCTyphoonKid
Report this Post06-17-2015 10:03 PM Click Here to See the Profile for NCTyphoonKidSend a Private Message to NCTyphoonKidEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't use the permatex wish I'd known that but I let the car sit till when I got off work this evening and filled it up and drove about 15-20 miles and all was well so far
