  3800 SC ll Automatic Question?
3800 SC ll Automatic Question? by James Bond 007
Started on: 06-14-2015 05:26 PM
Replies: 3 (298 views)
Last post by: Dennis LaGrua on 06-14-2015 07:23 PM
James Bond 007
Total ratings: 263
Report this Post06-14-2015 05:26 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
3800 SC ll Automatic, which neautral safety switch are you useing? The OEM fiero automatic Neautral Safety Switch or the OEM 3800 SC ll Automatic neautral safety switch.
Total ratings: 290
Report this Post06-14-2015 05:57 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to use the one that matches your engine/transmission/PCM.
The 3800 transmission switch has additional contacts in it to tell the PCM what gear the transmission is in.
The Fiero switch does not have that. Plus the Fiero switch was designed for 3 forward gear selections. The 4T65E has 4.
You must use the 3800 switch.
[This message has been edited by phonedawgz (edited 06-14-2015).]
James Bond 007
Total ratings: 263
Report this Post06-14-2015 06:56 PM Click Here to See the Profile for James Bond 007Send a Private Message to James Bond 007Edit/Delete MessageReply w/QuoteDirect Link to This Post
Now that makes sence (I have the correct switch).Thanks.
Report this Post06-14-2015 07:23 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my 06 3800SC series III swap I used the Grand Prix 03 neutral safety switch and the 03 PCM. I recall that the later 4T65eHD transmissions though have the selector switch internal to the transmissions but not the neutral safety.
