  Nobody can figure this one out, bet you can't.
Nobody can figure this one out, bet you can't. by 87FieroSport
Started on: 06-13-2015 11:25 PM
Replies: 21 (663 views)
Last post by: 87FieroSport on 06-17-2015 11:02 AM
87FieroSport
Report this Post06-13-2015 11:25 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
3800 Swapped, 1988 Fiero.
TL;DR - **** MPG.
Engine: 1999 Grand Prix GTP
Trans: 1999 GTP 4T65e-HD
PCM/Harness: Fieroflyer
So recently my mileage has gone down.. to 12mpg. I've never seen over 20 in the past two weeks of driving this thing.
I have a NEGATIVE, LTFT of between -14 and -17.1 while driving around.
Thing pisses through gas faster than I can imagine.
Here is what I KNOW:
Fuel pressure:
KOEO - 44psi at the rail
KOER - 40psi (no change with steady throttle, snap throttle = 45psi max)
Vacuum DC from FPR - 50psi
Engine vacuum - ~19.1
Replaced the o2 sensor, no change.
Nosrac believes a 1998 MAF was programmed into my 1999 PCM.
Another believes my Fuel pressure is too low, check for clogged fuel filter (Almost-new)
That's all I got right now. Too pissed to think of anything else.
87FieroSport
Report this Post06-13-2015 11:27 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
IDLE reading in Park for LTFT is:
-2.3 to -3
Drive reading, with no throttle is -7 LTFT.
Drive reading, in any case under load. -14 to -17.1 LTFT
WHY is it dumping so much fuel that it has to try and pull that much away?
thesameguy
Report this Post06-13-2015 11:44 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
So this thing is OBDII, yeah?
I would personally start by logging the MAF to see what the PCM thinks is happening. It's either adding the amount of fuel it thinks is correct, or incapable of properly metering fuel. I'd start with the easy one - be sure it's reading the MAF properly.
87FieroSport
Report this Post06-14-2015 12:05 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
2500hz @700-800rpm
3500-3800hz @16-1700rpm.
4800hz@ 1700rpm
5300hz@ 1300rpm mild throttle
5600hz@2100rpm @40mph
8100hz@3000rpm heavier throttle
5300hz@1800rpm @25mph
Not sure if this is meaning much I've been told my MAF readings are good, that it could be a '98 MAF table was programmed instead of a '99.
Steel
Report this Post06-14-2015 04:48 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cat clogged?
What are your running temps? Does it run very cool?
[This message has been edited by Steel (edited 06-14-2015).]
Tuna Helper
Report this Post06-14-2015 07:52 AM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bet my mileage is worse. I went through an entire tank in less than 100 miles.
hcforde
Report this Post06-14-2015 12:52 PM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Easy fix.............you have a hole in your gas tank!! JUST KIDDING GUYS, trying to add a little humor to what must be a frustrating situation.
Report this Post06-14-2015 02:31 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any DTC's show up on the scan? Your LTFT's are way off. I tune for numbers close to zero that would show that the PCM is not adding or subtracting fuel. +/- 5 is a good target +/- 10 is marginally acceptable but you should never see over that number.
Your engine is choking on fuel. Improper values in the MAF table/programming issues, defective sensor, clogged CAT or a leaking injector are possible causes.
thesameguy
Report this Post06-14-2015 03:39 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah... either your injectors are dumping fuel for no good reason (seriously oversized, seriously leaky, bad FPR, seriously high fuel pressure) or your maps are wrong. MAF readings seem okay, so it's either what the PCM is doing with that info or an inability to properly meter fuel.
lou_dias
Report this Post06-14-2015 04:05 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
a bad temp sensor would cause engine to dump fuel
87FieroSport
Report this Post06-15-2015 09:11 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update:
No CAT.
Plugged in my '99 Unprogrammed ECU, no change in LTFT.
Temp gets to 195 and steady.
Everything is stock besides the ZZP power log.
It'll stay at 0.0 to -0.7 at idle UNTIL I touch the gas.
Then it'll jump to -7.0 to -3.1 but driving it still hits almost -22.
MAF unplugged:
LTFT climbs to +30 and beyond.
I've been told to remove FPR vac line and run without it quick.
I've noticed that my voltages drop to 8 (no light coming on) I have to hold my AUX gauges down for it to come back up.
thesameguy
Report this Post06-15-2015 01:29 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wait, what?
87FieroSport
Report this Post06-15-2015 01:53 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dead serious lol. Around the time of **** mileage, r just a tad before (I have never gotten above 20mpg really)
My colts would shoot down to 8, if I tap on the AUX gauge it comes up to 11, sometimes back up to 13-14.
If I push the AUX gauges down, it keeps good voltage.
But anyhow, did a lot more tests earlier. No change in LTFT (idles at -12 now......)
thesameguy
Report this Post06-15-2015 02:11 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, got it. Maybe just a bad connection on the gauge. I thought you genuinely had 8v in the system!
This is just a 3800, no SC, yeah?
You should be able to drive around with the FPR unplugged ok. But, an easier test to connect a Mityvac to the FPR vacuum line and see if applying/removing vacuum from the FPR causes your wild AFR variations. Maybe you just have a bad/wrong FPR - although you're seeing 45psi max, which suggests it is behaving.
Do you have a noid light you could hook up the injectors to see how they're pulsing?
Or maybe build one of these?
http://www.impconcepts.com/...ormonitorforsale.htm
I had one years ago in my Saab - was handy when turning up boost!
[This message has been edited by thesameguy (edited 06-15-2015).]
87FieroSport
Report this Post06-15-2015 02:47 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Supercharged.
87FieroSport
Report this Post06-15-2015 02:49 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
87FieroSport
Member since Jul 2012
Dan, Stephen Poe, Scott, and a few other 3800 guys are clueless now.
The mystical 3800 that stumped em all
thesameguy
Report this Post06-15-2015 02:57 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay, then you'll need a Mityvac that can do pressure and vacuum. Test the FPR with both and see how the AFR numbers change - you should be able to hear/feel the mixture richen as you apply pressure to the FPR.
Also, as Lou said, have you checked resistance on the CTS?
87FieroSport
Report this Post06-15-2015 05:53 PM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another east test is disconnect FPR vacuum. Didn't get better, stayed the same.
thesameguy
Report this Post06-15-2015 06:20 PM Click Here to See the Profile for thesameguySend a Private Message to thesameguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not the same thing. Just disconnecting the FPR causes it to return to atmosphere, which is potentially very different than its response under boost.
Total ratings: 290
Report this Post06-16-2015 04:17 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is the part number stamped on your MAF? ends in 04 =98 and earlier 05 = 99+
sardonyx247
Total ratings: 219
Report this Post06-16-2015 06:01 PM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Do a compression test. A blown head gasket will tank mpg.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
87FieroSport
Report this Post06-17-2015 11:02 AM Click Here to See the Profile for 87FieroSportSend a Private Message to 87FieroSportEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not a head gasket.
160psi across the board, no misfires, no KR.
I put the OEM MAF back in, and I put the untuned 99 PCM in.
With the 99 ECM:
-14.8 LTFT max, -10.9-11.7 at cruising
With the 01-03 "tuned" PCM:
-20.3, -21.8 LTFT, -16.4-17.8 cruising.
99 PCM feels better, doesn't burn gas as bad as the "tuned" PCM.
