  4.9 engine to pass side coolant hose part # needed
4.9 engine to pass side coolant hose part # needed by jokerb90
Started on: 06-10-2015 06:08 AM
Replies: 2 (348 views)
Last post by: Raydar on 06-12-2015 06:09 AM
jokerb90
Report this Post06-10-2015 06:08 AM Click Here to See the Profile for jokerb90Send a Private Message to jokerb90Edit/Delete MessageReply w/QuoteDirect Link to This Post
Any suggestions? Rockauto is not very clear on this one, born 85 GT
thanks, Mike
whoops, found it!
https://www.fiero.nl/forum/Forum2/HTML/114536.html
[This message has been edited by jokerb90 (edited 06-10-2015).]
Report this Post06-10-2015 01:19 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
You did say 4.9L right.? The hose on the passenger side would be a standard right side 4 cyl. Engine to pipe hose.
[This message has been edited by Dennis LaGrua (edited 06-10-2015).]
Total ratings: 463
Report this Post06-12-2015 06:09 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The bottom hose? The one that connects between the passenger side pipe and the water pump?
My 4.9 uses the stock hose for the V6.
I had to use a long hose clamp around the cradle mount and the hose, to pull it forward, away from the compressor.
Mine is an 88. YMMV.
Praise the Lowered!
