  88 Suspension Issue / clearance on one side (Page 2)
88 Suspension Issue / clearance on one side by Racer_JT
Started on: 06-09-2015 06:50 PM
Replies: 41 (623 views)
Last post by: cyrus88 on 06-14-2015 09:43 PM
Racer_JT
Report this Post06-14-2015 07:38 PM Click Here to See the Profile for Racer_JTSend a Private Message to Racer_JTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I checked once again the springs are setting correct and they are.
I then measured everything once again and still getting the same results. The point of spring is different see pix above........WHY WHY WHY
Does the point where UCA meets perch look like this is all the cars????? I'm not sure it is not buggered up on the drivers side in the front?????
Rear of Drivers side
Front of drivers side
Rear of passenger side
Front of passenger side
cyrus88
Report this Post06-14-2015 09:43 PM Click Here to See the Profile for cyrus88Send a Private Message to cyrus88Edit/Delete MessageReply w/QuoteDirect Link to This Post
1) Are you sure the surface where you're park perfectly straight from side to side and front to rear?
I have an 88 with a V-8 swap with coilovers on all four corners. I had to adjust the drivers and passengers side differently on the front and rear to get the car to sit exactly level.
You may have to adjust your rear coilovers to shift weight off of the driver's side a little bit.
