  are all 3800sc the same?
are all 3800sc the same? by Darren's 87 coupe
Started on: 06-08-2015 04:06 PM
Replies: 12 (356 views)
Last post by: 85 SE VIN 9 on 06-12-2015 02:35 PM
Darren's 87 coupe
Report this Post06-08-2015 04:06 PM Click Here to See the Profile for Darren's 87 coupeSend a Private Message to Darren's 87 coupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thinking of doing my Fiero. Are they all the same? what about trans the can go with the swap?
Mike Gonzalez
Total ratings: 130
Report this Post06-08-2015 04:50 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is series I, II, and III. The engines withing each Series is the same, some of the accessory mounting is different. Dont bother with Series I, Series II and III can all be used running a 98-02 PCM. Series III needs some changes such as a different TB to work. You can use any of the Fiero Trans's, but theyre not too strong. Can use a Cavalier Getrag F23, or the auto 4T64E thats on the 3800.
Total ratings: 290
Report this Post06-08-2015 06:15 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dont bother with Series I.
Fixed
Mike Gonzalez
Total ratings: 130
Report this Post06-08-2015 06:24 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
lol, put a comma where i meant to put a period.....punctuation matters kids :-P
Report this Post06-08-2015 07:25 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Most swaps are done using the 3800SC series II engines 99-02 and the 4T65eHD 4 speed automatic for reliability. I would suggest that you stay away from using the Getrag stick as the Fiero transmissions were not designed to take the type of power that the 3800 puts out. Some swaps are using the F23 stick that is used in Cavaliers, and Cobalt and it is claimed to be stronger but that too is rated for a light duty 170 ft lbs of torque.
A step up would be the 3800SC series III (04-07) 4T65eHD but it uses drive by wire controls and its a difficult swap to get working. As a result most series III swaps use the earlier cable operated throttle body and the 03 GTP PCM. Since the series III operated with more boost and made more power, using it with the earlier PCM requires extensive re-programming.
Darth Fiero
Total ratings: 361
Report this Post06-08-2015 09:06 PM Click Here to See the Profile for Darth FieroClick Here to visit Darth Fiero's HomePageSend a Private Message to Darth FieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by phonedawgz:
Fixed
Please check your PM's and emails.
OVERKILL IS UNDERRATED
Darren's 87 coupe
Report this Post06-08-2015 10:51 PM Click Here to See the Profile for Darren's 87 coupeSend a Private Message to Darren's 87 coupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you guys very much
Report this Post06-09-2015 07:49 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Almost forgot to mention. If you are a die hard stick man the GM F40 6 speed transmission is plenty strong to take a 3800SC swap. Rated to 295 ft lbs of torque it should be reliable. The downside is that it requires some extensive modifications to fit, starting with the replacement of the shifter.
Darren's 87 coupe
Report this Post06-10-2015 12:00 PM Click Here to See the Profile for Darren's 87 coupeSend a Private Message to Darren's 87 coupeEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, it would be an auto.
85 SE VIN 9
Report this Post06-11-2015 12:24 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you buy a 3800 crate engine can you put a supercharger on it or are the internal parts different?
Has anyone done a Cobalt swap? There is even a supercharged Cobalt. In fact there is supposedly one with inboard front brakes. Could you swap the whole drivetrain like they did originally to create the Fiero?
Report this Post06-11-2015 04:21 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800 N/A uses different pistons and rods. You can put a supercharger on it but you will need what is called a "top swap" ...different intake manifold fuel rail etc.
As for the Cobalt, that's an Ecotec engine. Several Ecotec swaps have been done on Fieros but it is an involved process.
fierosound
Total ratings: 286
Report this Post06-11-2015 06:45 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Many Ecotech swaps are started but never finished.
https://www.fiero.nl/forum/Forum1/HTML/091490.html
Long running threads
https://www.fiero.nl/forum/A...100421-2-078384.html
https://www.fiero.nl/forum/A...130314-2-045570.html
Calgary time/temp
[This message has been edited by fierosound (edited 06-11-2015).]
85 SE VIN 9
Report this Post06-12-2015 02:35 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
"Different pistons and rods" is what I figured. "Different" as in "stronger," right? You 'could' put a supercharger on it, but it might not be any more reliable than a used SC engine, correct?
