  Single hose from EGR servo: eliminate?
Single hose from EGR servo: eliminate? by imacflier
Started on: 06-08-2015 06:53 AM
Replies: 1 (98 views)
Last post by: Gall757 on 06-08-2015 08:39 AM
imacflier
Report this Post06-08-2015 06:53 AM Click Here to See the Profile for imacflierSend a Private Message to imacflierEdit/Delete MessageReply w/QuoteDirect Link to This Post
'88 GT, Manual: There is a 7/32" rubber line that leads from the single connection fitting on the EGR servo to the metal line that goes across the cabin firewall. I believe that the OTHER end of the metal line terminates in the air cleaner (part of one of the recalls, IIRC). That makes that line nothing more than an air intake line. Can I remove the hose? The EGR servo would then be taking in unfiltered engine compartment air. Mine hose is pretty well rotted and it takes longer and thinner arms than mine to slide a new hose onto the metal line!
I am setting no codes and the idle is fine, so I know of no reason to keep that rubber hose
Whatcha think?
TIA,
Larry
Report this Post06-08-2015 08:39 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
You are correct. GM wanted to provide filtered air to the solenoid as a precaution. I suppose if you live on a gravel road or a high dust area you could mess up the solenoid.
