  1984 Engine/Transmission - what Fiero's will this directly swap into?
1984 Engine/Transmission - what Fiero's will this directly swap into? by Steel
Started on: 05-30-2015 09:11 PM
Replies: 3 (164 views)
Last post by: Steel on 05-31-2015 03:34 PM
Steel
Report this Post05-30-2015 09:11 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a very nice low mile engine and auto transmission from a 1984 Fiero.
Is this a direct drop in for 84-86 4-cylinder Fiero's that were automatics?
I'm looking for a clean frame platform to swap these into. Something without major rust damage that needs a new engine etc.. and I'd like to find something that this will basically directly bolt into without a bunch of money and changes involved.
[This message has been edited by Steel (edited 05-30-2015).]
Custom2M4
Total ratings: 114
Report this Post05-30-2015 11:58 PM Click Here to See the Profile for Custom2M4Send a Private Message to Custom2M4Edit/Delete MessageReply w/QuoteDirect Link to This Post
Directly the same... 84 only.
Will it work in an 85-86, yes. But make sure you have the entire motor because they are different internally. I've also heard you need to use the 85-86 distributor. 87-88 will not work.
Report this Post05-31-2015 12:18 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Engine wiring harness, Distributor, coil, OP sender, and TBI are different for 84 vs 85-86.
Depending on several things engine internal are same or different because car options and/or recall/warranty engine replacement.
Other items covered in my Cave, Duke Quick Ref
Steel
Report this Post05-31-2015 03:34 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ahh thanks guys. Ogre excellent info in your cave I can't believe I never saw it before now.
I guess I'll try to get an '84 for a few weeks then consider the later years if I don't have luck~
+'s for both of you.
