  cooling can comes on, volts drop 84
cooling can comes on, volts drop 84 by vette7584
Started on: 05-29-2015 02:15 PM
Replies: 1 (65 views)
Last post by: cptsnoopy on 05-29-2015 02:40 PM
vette7584
Report this Post05-29-2015 02:15 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
just recharged ac in my 84. when i switch it on, the voltage drops to around 11 volts. belt is good and tight on alternator, runs high 13 other wise. if i unplug cooling fan and turn on ac, no issues with voltage drop. fans turns smoothly, and resistor had been removed from fan wiring, not sure what happens when fan kicks on when up to temperature. any thoughts?
cptsnoopy
Total ratings: 60
Report this Post05-29-2015 02:40 PM Click Here to See the Profile for cptsnoopySend a Private Message to cptsnoopyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Normal for me. If it is draining the battery and leaving it without a charge then maybe your alternator or corroded wiring?
The fan definitely draws some amps.
Charlie
