  High Temp Issue
High Temp Issue by FieroJosh1993
Started on: 05-28-2015 11:11 PM
Replies: 27 (532 views)
Last post by: ILVMYGT on 06-25-2015 10:18 PM
FieroJosh1993
Report this Post05-28-2015 11:11 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hey everyone, So ive searched the forums for this issue and can't find a match to my problem
I have a 87 GT auto and when I drive on a warm day or even on a cool day and push the engine ( which is brand new ) my temp will reach red hot on the gauge. The coolant light doesnt come on but I know im close to turning it on.
Heres what I have found out and tried.
So if I run the car with out a thermostat it takes longer for the engine temp to get red hot. but it still will reach max temp on the gauge if I drive it long enough. When i put a thermostat in, it will reach the max on the temp gauge within 10 mins of driving.
I have checked and I DONT have a head gasket leak. I have burped the cooling system three times. I replaced the fan relay and the fan motor. I even replaced the fan switch. Still gets hot.
When i did my engine swap last year I did take the a/c compressor off the car, I decided I didnt need a/c and I didnt want to get a new one. my question is, will this cause the fan not to kick on?? Could really use some help on this problem, its got my stumped.
Thanks
fieromatty
Report this Post05-28-2015 11:22 PM Click Here to See the Profile for fieromattySend a Private Message to fieromattyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you know if your radiator fan is coming on?
FieroJosh1993
Report this Post05-29-2015 06:53 AM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
well I read that if I flip the a/c to max a/c and the fan speed to max it should come on. Ive done that and It doesn't, but I didnt know if that was because I dont have a compressor.
[This message has been edited by FieroJosh1993 (edited 05-29-2015).]
Report this Post05-29-2015 08:03 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The HVAC control head turns on the fan when any A/C position is selected. The absence of the compressor has no bearing on the cooling fan function.
The cooling fan circuit can be checked by grounding the wire for the thermostatic fan switch on the engine. If the grounded wire turns on the fan the relay and fan are good.
FieroJosh1993
Report this Post05-29-2015 04:44 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
so how is the best way to ground it. Key on engine off and the unplug the fan switch and ground it to the negative battery cable??
Report this Post05-29-2015 04:45 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
engine block
FieroJosh1993
Report this Post05-29-2015 04:49 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
oh ok, just ground it to the block. gotcha, will give this a try,
anymore ideas would be great.
Report this Post05-29-2015 06:09 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check this first, then we will move on if needed.
Report this Post05-29-2015 06:33 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2004
For accuracy of information.....
Blower fan speed has nothing to do with the cooling fan function via the HVAC head.
The HVAC head provides a path to ground for the Cooling Fan Relay coil when in MAX, BI and NORM a/c settings. The other ways the relay can be fired are the Coolant Temperature Switch (above 235°F), and the A/C High Pressure Switch (over 280 psi).
Since your GT is an 87, the Engine Blower Relay should also turn on the Engine Blower Fan in the trunk at the same time.
Grounding the temp switch wire or turning the HVAC control to an A/C setting are the two easiest ways to check the function of the fan relay and the fan motor.
Have you checked fuse "FAN E" (20A)? It supplies power to the fan and the relay.
Report this Post05-29-2015 06:51 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
While the car's actually moving?
If your gauge is showing the correct temperature (and that's not a given), I suspect your Fiero has cooling system issues... and I'm not referring to your fan not coming on.
While your Fiero is moving (and air is being pushed through the rad), there's no way your engine should be overheating after any length of time of driving.
But yeah, if your car is sitting still, the fan eventually needs to be kicking on.
84fiero123
Total ratings: 325
Report this Post05-29-2015 08:23 PM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ayup, I don't think mine has come on ever no matter how hot it is when driving, ever. But I do live in Maine so that may have something to do with it. First are you sure the temp gauge is right? I grabbed one of my wife's candy thermometers and just lay the probe right on the thermostat housing. unless you know someone with a touch less laser thermometer nearby you can borrow. the candy thermometers are under 5 bucks, the laser ones start around 30 buck to be sure those are the only ways to get a real temp reading.
like some one else said these thing are famous for reading wrong, hell the one in my Burb never goes above like 150 but the thermostat works and I checked the temp of the engine sitting in the yard running and it runs right around 200 or just a little higher ever, I just hauled our horse trailer full of hay today. I hate electrical gauges they are bad, sometimes way off like my burbs. And all it maybe is a bad wire or sensor.
Oh ya and welcome aboard the nut ship, we have to be nuts to want to drive around in 25+ year old cars.
edit to add, if you do use the wife's or moms candy thermometer go get her a new one, lives have been lost for doing less.
Steve
[This message has been edited by 84fiero123 (edited 05-29-2015).]
FieroJosh1993
Report this Post06-16-2015 01:08 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
ok sorry its taken so long to post back, was in the hospitle with my mom.
So when i ground the fan switch wire to the block the fan does come on. But when Im driving and the temp reaches 235 degrees the fan doesnt kick on. So what is the issue?? Its a new fan switch, replaced it when i did the engine swap.
Thanks guys
Report this Post06-16-2015 03:43 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Either your new switch is bad, or it is not getting a ground contact through the threads....did you use teflon tape?
also: If you are reading 235* on the temp gauge, it may be way off. 10% error is not unusual.
[This message has been edited by Gall757 (edited 06-16-2015).]
FieroJosh1993
Report this Post06-16-2015 04:12 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
I didnt put tape on the switch but it did have something on the threads. i dont think it was tape, might have been an anti seize, not sure. So what would be the next best step, get a new sensor or try and clean up the current one and see if it was just not getting a good ground??
[This message has been edited by FieroJosh1993 (edited 06-16-2015).]
Csjag
Report this Post06-16-2015 04:23 PM Click Here to See the Profile for CsjagSend a Private Message to CsjagEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the car is overheating while moving you may also have a clogged radiator
FieroJosh1993
Report this Post06-16-2015 04:27 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
whats the best way to tell if the radiator is clogged, without just buying a new one. any tests I can do??
FieroJosh1993
Report this Post06-16-2015 04:46 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
FieroJosh1993
Member since Sep 2012
I will have to save up for a new radiator, but for now, has anyone ever wired a toggle switch for the radiator fan, So I can just flip it on when im driving?? How would you do this. i.e. best place to put the switch best place to get power from. if anyone could tell me how or if you have a step by step or video that would be great.
Report this Post06-16-2015 05:17 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Don't borrow trouble. The next time the car is hot, feel the exit hose on the radiator. If it is cool...lukewarm, it is blocked. Both the inlet and output hoses should feel hot.
As for the switch, I would clean the threads and put it back in. You should be able to ground the wire on the hex part of the switch and prove that the ground contact is working. If it is working, you probably have a new bad switch....not that uncommon these days, sorry to say.
Report this Post06-16-2015 05:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You never answered my question earlier... but if your engine overheats while the car is moving, then installing a manual fan switch is pointless. Find the actual problem!
[This message has been edited by Patrick (edited 06-16-2015).]
ag9123
Report this Post06-16-2015 05:40 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you check for pinched coolant tubes under the car? Improper jacking can crush those very easily..
FieroJosh1993
Report this Post06-16-2015 06:03 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
oh sorry patrick, the car doesnt over heat when im moving fast, but if I sit at a light for a long time or move like 30mph or under it gets hot.
I checked all under the car and the tubes look fine.
I just got back from the store and felt both radiator hoses. they are both hot. so its not a blocked radiator. i will check the switch to make sure it has a good ground.
Report this Post06-16-2015 06:28 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...or move like 30mph or under it gets hot.
I dunno, but I suspect there are cooling issues that won't be solved by switching the fan on manually. As long as the car is actually moving forward, the natural flow of air through the rad should be enough to maintain proper cooling.
Have you had the engine scanned to see its actual temperature? Other than the dash temp gauge (which is notorious for being wrong) reading high, what leads you to believe your Fiero is overheating?
FieroJosh1993
Report this Post06-16-2015 06:50 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
well, the only time was when the coolant light came on. I never have gotten it that hot again, but if the gauge is wrong then how to I get it to a somewhat accurate reading. The only reason I say the car is getting hot is because the gauge maxes out and i just go home cause I dont want to damage the engine.
Report this Post06-16-2015 06:56 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
To tell the truth, I don't know how that light is triggered. It could be a false alarm as well.
You need to find out the actual temperature. With my own Fiero(s), I'd connect my laptop to the ALDL connector and run WinALDL. Or if a scanning device is available, use that.
FieroJosh1993
Report this Post06-16-2015 07:04 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
so I have a scan tool at work that says it works for obd2 and before, I should be able to see the temp of the engine. I will give this a shot tomorrow. Thanks
Report this Post06-16-2015 07:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
so I have a scan tool at work that says it works for obd2 and before...
Although I was referring to WinALDL in the following post, This applies to using a scanner as well.
FieroJosh1993
Report this Post06-24-2015 04:16 PM Click Here to See the Profile for FieroJosh1993Send a Private Message to FieroJosh1993Edit/Delete MessageReply w/QuoteDirect Link to This Post
Update,
Ok so ive done a few things since the last post. I check the temp when the gauge says its in the red and the real temp is 245 degrees. I checked the fan switch and the sensor was not making a good ground to the engine. Replaced it and burped the cooling system. So far I have noticed a difference. I still am getting past 235 degrees and the fan still isnt coming on. Not sure why. Also now I have a strong gas smell coming from the engine area but I cant locate a leak.
ILVMYGT
Report this Post06-25-2015 10:18 PM Click Here to See the Profile for ILVMYGTSend a Private Message to ILVMYGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
The GTs have an air dam in front of the radiator to help push the air up in the it. Does your car have the air dam installed? It won't help at a stop light but once moving it will.
88 GT 5 Speed Black with gray interior
3800 SCII Swap Complete.
Paint Complete
Detailing in Progress
IT RUNS!!
IT'S QUICK!!
"Real integrity is doing the right thing, knowing that nobody's going to know whether you did it or not."
