Update System
  Clutch pedal soft after car has been in storage?
Clutch pedal soft after car has been in storage? by boysatt
Started on: 05-27-2015 01:22 PM
Replies: 4 (144 views)
Last post by: zzzhuh on 05-27-2015 07:58 PM
boysatt
Report this Post05-27-2015 01:22 PM Click Here to See the Profile for boysattSend a Private Message to boysattEdit/Delete MessageReply w/QuoteDirect Link to This Post
So I haven't driven my fiero in 2 years, its been in storage. Right now I cannot get it into gear while running, the slave does not start to move till I have the clutch petal half way to the floor. Even if I pump the hell out of it I can't get anymore pressure. The master and slave were new 2.5 years ago with only 1000 miles on them. Is it possible from sitting that the master failed?
Mike
Total ratings: 465
Report this Post05-27-2015 03:00 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You've probably got air in the system. It needs to be bled. My experience is that nine times out of ten, the seal in the slave is what has failed.
Was the new slave you installed a couple years ago a dual-seal one from Rodney? If not... get one!
boysatt
Report this Post05-27-2015 05:41 PM Click Here to See the Profile for boysattSend a Private Message to boysattEdit/Delete MessageReply w/QuoteDirect Link to This Post
No it was a OEM GM NOS part. I'll have to order one from him, maybe he'll be at the Dells show this weekend.
Total ratings: 465
Report this Post05-27-2015 05:52 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, unfortunately the original single-seal style Fiero clutch slaves are next to useless.
zzzhuh
Report this Post05-27-2015 07:58 PM Click Here to See the Profile for zzzhuhSend a Private Message to zzzhuhEdit/Delete MessageReply w/QuoteDirect Link to This Post
I agree with Patrick. My Master Cylinder was leaking and it was next to impossible to take the cap off to fill it back up. Roney's is a higher quality replacement that is made of Metal.... Not plastic. Plus, the cap is a very easy 1/2 turn and pull. Much better design IMO.
