  leaking thermostat housing cap
leaking thermostat housing cap by tshark
Started on: 05-26-2015 02:06 PM
Replies: 7 (320 views)
Last post by: theogre on 05-27-2015 03:59 PM
tshark
Report this Post05-26-2015 02:06 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
jaskispyder
Total ratings: 205
Report this Post05-26-2015 02:10 PM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clean up the surface where the cap mounts. I had some surface rust that caused new cap to leak.
Report this Post05-26-2015 02:24 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Leaking in middle mostly means the cap is bad because The rivet that holds the rubber etc is likely the problem.
Leaking at edge could be cap problem or very likely problems w/ Tstat housing.
I only use Stant caps. I have problems using other brands. Recent Example, Some "Store Brand" are made by MotoRad. MotoRad looks ok but I had fitment issue w/ their Tstat caps on 87 L4.
[This message has been edited by theogre (edited 05-26-2015).]
tshark
Report this Post05-26-2015 06:34 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
jaskispyder
Total ratings: 205
Report this Post05-27-2015 07:17 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
take it back to the store and exchange it.
tshark
Report this Post05-27-2015 08:22 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
jaskispyder
Total ratings: 205
Report this Post05-27-2015 08:23 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
Ship it back? Yeah, if I can find my receipt.
Stop into a local parts store and buy one there. Ship the other one back.
Report this Post05-27-2015 03:59 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is Stant. Or, the box it came in is. Yes, it leaks around the rivet or thatever that thing in the middle is. Brand new. Very annoying.
The question is, where can I find a good (correct) one?
Wow... Very few Stant caps have problems.
I still won't trust Levrvent types but all others are good to me and been use them for many Many years. (Levrvent can wears out the seal area for lever part for DIY open the system often. Bigger problem when cars didn't use reserve tank.)
Order online then check Email for invoice too.
MotoRad parts for store band label still use same number stamped into the top but often use different SKU etc. AZ Oriely etc use then under different names. PN on the package could be different.
You can try them but I had no luck using Tstat cover. There are small difference in housing... At least 2 versions just for L4 "duke" engines.
[This message has been edited by theogre (edited 05-27-2015).]
