  88 v6 alternator not charging
88 v6 alternator not charging by tom10122
Started on: 05-26-2015 09:28 AM
Replies: 5 (203 views)
Last post by: tom10122 on 05-26-2015 01:07 PM
tom10122
Report this Post05-26-2015 09:28 AM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
On my way to class today I noticed my voltmeter reading alittle low, around 12v just above the red. Normally I'm somewhere between 13 and 14 atleast. I'm between classes and checked the battery with a multimeter and I have 12.6v there, which sounds like it was being charged. If I turn the key to the on position the voltmeter actually shows alittle higher than when the car was running. When I'm done I'm going to start it and check again with it running.
Are there any fusible links I can check out? Any tests I can do with my meter without wasting charge?
BTW I just replaced my rotor, distributor cap, icm and ignition coil last week but I don't see how this would affect the alternator.
Report this Post05-26-2015 09:33 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Key on, engine off.....is the VOLTS light on?
tom10122
Report this Post05-26-2015 09:53 AM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes it is
84fiero123
Total ratings: 325
Report this Post05-26-2015 09:57 AM Click Here to See the Profile for 84fiero123Send a Private Message to 84fiero123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check and clean all connections coming from the battery and alternator, sometimes it can be just a lose connection.
But your battery sounds a little low, it should be almost 13 volts sitting, almost.
Steve
tom10122
Report this Post05-26-2015 10:29 AM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
Can't find anything obvious, was charging yesterday. When I get home I'll take a look in my Haynes manual and see if there's any tests I can do. My battery was replaced June of last year too.
[This message has been edited by tom10122 (edited 05-26-2015).]
tom10122
Report this Post05-26-2015 01:07 PM Click Here to See the Profile for tom10122Send a Private Message to tom10122Edit/Delete MessageReply w/QuoteDirect Link to This Post
tom10122
Member since Jul 2014
Made it home and am charging it now, charger said it was at 25%, once it's charged I'm going to try the alternator check option on the charger
Continuity from the big leg of the alternator to the pos side of the battery and the charger said it was bad.
