  Need help attaching stainless braided trans sport fuel lines to fiero fuel lines
Need help attaching stainless braided trans sport fuel lines to fiero fuel lines by Lou and Blue
Started on: 05-25-2015 07:51 PM
Replies: 10 (690 views)
Last post by: Lou and Blue on 05-27-2015 08:17 PM
Lou and Blue
Report this Post05-25-2015 07:51 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am trying to install them using compression fittings and I don't know if its because the fitting is brass and the tube is steel but the fitting will not tighten.it just pops the thread from the collar off the thread in the inner fitting part when i try to tighten it. Am I using the wrong compression fitting.
I thought it was a Regular brass compression fitting 3/8 or feed line and 5/16 for return line.
I bought the fittings from pepboys. It says gator grippers and it says not for brake line use.
Please help!
Thanks !
Louis Duet
Baldwin, Long Island, NY
"My mind spins like helicopter blades." -G. Rossdale
"Blue" <= '85 Fiero GT
3800sc series 2 swap in progress
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Peugot 604 Intake manifold
Exhaust headers
Anti-3rd brake light
Lou and Blue
Report this Post05-26-2015 01:37 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I think I'm just gonna go with flared brake lines and attach the lines by flaring them.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
Fierofreak00
Total ratings: 170
Report this Post05-26-2015 01:47 PM Click Here to See the Profile for Fierofreak00Send a Private Message to Fierofreak00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Should be standard Brass fittings for steel line (not nylon) When you tighten them, they should NOT pull apart... Seems to me that you might have gotten the wrong ones... -Jason
These ones are Dorman sold at Advanced Auto parts (other stores should be similar)
3/8 http://shop.advanceautopart...compression+fittings
5/16 http://shop.advanceautopart...compression+fittings
Lou and Blue
Report this Post05-26-2015 04:16 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm gonna flare the ends and attach them that way so it ensures no leaks.
But is it a single or double flare? The lines I bought look like double flare but they say standard flare. The flaring tool can make either. Now I'm getting confused on what type of flare I should make.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
Lou and Blue
Report this Post05-26-2015 04:18 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou and Blue
Member since Dec 2013
I am running new flared lines because I mistakenly cut the OEM fuel
Lines down by the filter which is too low for the stainless braided lines to reach.
Lou and Blue
Report this Post05-26-2015 08:39 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou and Blue
Tried flaring the braided line end but it was to hard to flare and screwed up my tubing but hopefully I have enough I can try the compression fitting again.
Also broke auto zones loaner flaring tool in the process. Autozone still refunded my money though at least.
Trying again another day.
Thanks go out to Scott2Scott and Ryan from sinister for their help trough all this madness !
Many emails and I'm very thankful for that!
This forum is like a pair of good pantyhose , lots of support.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
2002z28ssconv
Total ratings: 51
Report this Post05-26-2015 10:05 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
That should have worked. The sleeve should have been pretty snug on the tube. Was it loose? That sleeve gets a bit crushed between the fitting's body and nut. That's what makes the seal.
Is it actually breaking the fitting or just striping the threads?
Either way, too tight.
Maybe they are low quality.
Was it loose on the fuel filter side or the stainless hose side? Your factory lines may have been corroded which could prevent getting a good seal.
You could always go to AN lines. But that will cost over $100 for the hose and fittings. And you still have to get a 37 degree AN flare tool too.
Bottom line though, these should work.
[This message has been edited by 2002z28ssconv (edited 05-26-2015).]
Lou and Blue
Report this Post05-27-2015 04:01 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
The gator gripper I tried first is the exact one in that picture. I think it stripped the threads the first time
I tried to tighten it. Anything past finger tight caused it to pop apart , I think because of the e stripped thread.
Now I'm just hoping that there is enough tubing that's not mangled on my 3/8 feed line (part of the braided line) after unsuccessfully trying to flare the end and i hope now that a compression fitting will grab. I am using new brake line coming out of the filter running up the side wall so no pitting there. I only tried it on the stainless side so far anyway.
Ill try again and let you guys know what worked and what didn't.
Ill have to get a new fitting because of this one being stripped . The fitting didnt break it would just pop the threads. I never got a chance to tighten it.
Those AN lines are ridiculously expensive so im trying what I can first.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
[This message has been edited by Lou and Blue (edited 05-27-2015).]
Lou and Blue
Report this Post05-27-2015 06:19 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou and Blue
OK, so brake tubing bending didnt go so well, and the tubing bender wouldn't let me make a tight bend out of the filter.
See my "want to buy a set of OEM v6 fuel lines from tank to top of engine "post in the mall.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
2002z28ssconv
Total ratings: 51
Report this Post05-27-2015 06:46 PM Click Here to See the Profile for 2002z28ssconvClick Here to visit 2002z28ssconv's HomePageSend a Private Message to 2002z28ssconvEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you want, I'll bend a set that matches the originals for you if you can't find one. I will even put a 45 degree double flare on it too.
Lou and Blue
Report this Post05-27-2015 08:17 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pm sent.
