  Question about oil filter brand SIZE difference
Question about oil filter brand SIZE difference by Kitskaboodle
Started on: 05-22-2015 11:59 PM
Replies: 8 (961 views)
Last post by: steve308 on 05-23-2015 05:36 PM
Kitskaboodle
Report this Post05-22-2015 11:59 PM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I sometimes use Bosch filters but sometimes I use Wix . Why is it that the Wix filter is much longer in length than the Bosch? (This is for an 86 GT) The correct Bosch number is 3331 while the Wix is 36015.
So, they don't have to be the same length regardless of brand?
Signed, I'm Confused
Report this Post05-23-2015 08:55 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Both brands probably make both sizes. Those little filters were popular in the 80s....but larger filters have advantages too, so many people have switched to them.
Are you sure you have that WIX number right?
http://www.oilfilter-crossreference.com/
[This message has been edited by Gall757 (edited 05-23-2015).]
Kitskaboodle
Report this Post05-23-2015 09:18 AM Click Here to See the Profile for KitskaboodleSend a Private Message to KitskaboodleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, I was going by memory. The correct Wix number is 51036, not 36015.
I did notice that the Bosch filter, though much shorter is much denser & heavier than the much longer Wix.
Kit
Report this Post05-23-2015 09:25 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Bosch 3430 will be the same size as the wix 51036. (according to that cross reference page)
There is a very good thread here on PFF about what's inside the different brands. There are a lot of differences in filter construction.
Report this Post05-23-2015 09:35 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Correct" filter for V6 is GM/ACDelco PF47, the smaller one.
Other brands make both or only make the longer size one.
See my Cave, Oil and Filter
Report this Post05-23-2015 10:32 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've always used the longer AC Delco PF-52 filters. They have the same pattern as the PF-47 but have more filter medium. I believe that they are directly interchangeable. It should be noted that not all oil filters are alike. Some brands use longer more dense filter mediums. I read an article a while back and it gave some good info; [url] http://www.austincc.edu/wkibbe/oilfilterstudy.htm [/url]
[This message has been edited by Dennis LaGrua (edited 05-23-2015).]
RWDPLZ
Total ratings: 305
Report this Post05-23-2015 01:59 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cannot recommend using the PF52 any more.
https://www.fiero.nl/forum/A...110502-2-105372.html
The Wix 51036 is a good replacement. I cut apart several Fiero specific filters, and Wix was by far the best.
Another good comparison
http://www.300cforums.com/f...lters-dissected.html
css9450
Total ratings: 86
Report this Post05-23-2015 02:40 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
The new AC Delco is their "E-core" filter.
I just use the old ones. Still available, at least around here.
steve308
Total ratings: 58
Report this Post05-23-2015 05:36 PM Click Here to See the Profile for steve308Send a Private Message to steve308Edit/Delete MessageReply w/QuoteDirect Link to This Post
Longer filter is easier to get on and off.
