  Help! Fuel tank strap bolt came out of flange
Help! Fuel tank strap bolt came out of flange by Lou and Blue
Started on: 05-21-2015 06:10 PM
Replies: 6 (585 views)
Last post by: Lou and Blue on 05-23-2015 07:59 AM
Lou and Blue
Report this Post05-21-2015 06:10 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
While dropping my fuel tank to swap the pump today, the front strap nut was so tight and wouldn't loosen anymore that it pulled the T-shaped bolt out of the flange. I cannot loosen the nut anymore . The t-shaped bolt is still thought the strap. I don't know if I should cut the t-shaped bolt off with a bolt cutters and look for a replacement T-shaped bolt and nut. Is that available?
I did get the tank out and have yet to tackle the actual fuel pump replacement, but I'm worried about this when I reinstall the tank.
Has anyone had this issue before or know what I can do to the front strap to reinstall my tank?
Thank you.
Louis Duet
Baldwin, Long Island, NY
"My mind spins like helicopter blades." -G. Rossdale
"Blue" <= '85 Fiero GT
3800sc series 2 swap in progress
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Peugot 604 Intake manifold
Exhaust headers
Anti-3rd brake light
Lou and Blue
Report this Post05-21-2015 06:20 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fiero store sells replacement t bolts. I would guess that means they snap in to the welded flange on the body of the car. I will try to get mine apart using heat or some thing and reuse the t bolt.
css9450
Total ratings: 86
Report this Post05-21-2015 08:34 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yeah, the "T" shaped part of the bolt just sits in a little "pocket" on the underside of the carbody tunnel. Assuming you haven't damaged the pocket, get new bolts and you'll be golden.
New tank straps are available too.
Neils88
Total ratings: 56
Report this Post05-21-2015 08:39 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
I agree...replace them all. They pop in easily.
Lou and Blue
Report this Post05-22-2015 11:58 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
I ended up hitting the t bolts wth a wire wheel and it cleaned up the threads nicely. I swapped the pump and replaced the tank today. Thank you everyone.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
Report this Post05-23-2015 03:01 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
You soaked it with PB Blaster (or equivalent) first, right?
Lou and Blue
Report this Post05-23-2015 07:59 AM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yea, I used aerokroil on it but what worked best was my drill attachment wire wheel. I got the nut off lickety split after that.
