  Fiero store dash cover
Fiero store dash cover by Wittendorf1986
Started on: 05-20-2015 07:07 AM
Replies: 3 (606 views)
Last post by: Dennis LaGrua on 05-21-2015 07:13 PM
Wittendorf1986
Report this Post05-20-2015 07:07 AM Click Here to See the Profile for Wittendorf1986Send a Private Message to Wittendorf1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was wondering if anyone installed the fiero store dash board cover, I was thinking of getting it but wondering what is the best way to install it does the dash have to be removed or ?
Report this Post05-20-2015 07:53 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have an application for one but I believe their dash cover is a hard plastic shell that glues over the existing dash. The problem with this is that with no flex in the dash, it may be easily cracked. Most often the sides of the dash are where cracks appear. The Fiero Store also makes dash end caps. They also glue over the end vents but it might make more sense to use these in cases where the dash cracks exist there. There are also flexible dash fillers that you can use to repair, see here: [url] http://www.urethanesupply.c...r-Cracked-Dashboard/ [/url]
Wittendorf1986
Report this Post05-20-2015 10:26 PM Click Here to See the Profile for Wittendorf1986Send a Private Message to Wittendorf1986Edit/Delete MessageReply w/QuoteDirect Link to This Post
So how do you go about painting the dash what is the easiest and best way to do it I have never painted interior before
Report this Post05-21-2015 07:13 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The entire process is shown on the website link above by Urethane supply. You cannot just paint over dash material. You need a version of a plastic adhesion promoter.
