  Cam
Cam by Nick8434
Started on: 05-19-2015 01:19 PM
Replies: 1 (77 views)
Last post by: dobey on 05-19-2015 01:38 PM
Nick8434
Report this Post05-19-2015 01:19 PM Click Here to See the Profile for Nick8434Send a Private Message to Nick8434Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have been debating for a while on my cam choice and I need some of your guys input and what you think would be best. It's between the xpz or intense stage 3 or 4 blower cam. Ill be running a gen v with a highly modified motor obviously different heads as well/ Ill have the getrag 282. Ill do some drag racing but will be driving on the street but it won't be my daily driver. I understand cams and all the specs but just curious with any with personal experience or what other may think. Thank you
dobey
Total ratings: 371
Report this Post05-19-2015 01:38 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was it really necessary to start a new thread to ask the same basic question for which there is already an active thread you started?
https://www.fiero.nl/forum/Forum2/HTML/135517.html
What are the specs on the cams? What's the torque curve like with each one?
Ideally, if you want to drag race occasionally while still driving it on the street most of the time, you'll want a cam that helps you to broaden the curve into the higher RPM range, without sacrificing much on the low end. Pick whichever cam does that for you.
