  Dumb ass question time (3800 exhaust)
Dumb ass question time (3800 exhaust) by Tuna Helper
Started on: 05-17-2015 08:30 PM
Replies: 4 (278 views)
Last post by: Tuna Helper on 05-18-2015 08:06 PM
Tuna Helper
Report this Post05-17-2015 08:30 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm looking around and seeing that some are using exhaust manifolds from a 2000+ camaro with 3.8. Is there a reason not to use the earlier rams horn style manifolds? This is on a stock engine. Reason is I am having trouble with the shifter cables on my 4 speed and if I get rid of the crossover I can put the cable back to stock and have second gear back.
I don't know if I bent something, but when I replaced my clutch I lost the ability to shift into second. The levers hit each other. This is what I have done to clear the crossover.
mitchjl22
Report this Post05-18-2015 12:12 AM Click Here to See the Profile for mitchjl22Send a Private Message to mitchjl22Edit/Delete MessageReply w/QuoteDirect Link to This Post
This may help
From Paul's Thread Here
[This message has been edited by mitchjl22 (edited 05-18-2015).]
Tuna Helper
Report this Post05-18-2015 06:04 AM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's pretty much what I did.
A friend was looking at my car yesterday and was talking about cutting a bracket and lowering the shift arm, I'm not sure about cutting the bracket. This looks like a less permanent solution.
[This message has been edited by Tuna Helper (edited 05-18-2015).]
DKcustoms
Report this Post05-18-2015 05:15 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Holy zip ties batman.
That's why I'm doing a true dual, going to try and keep the exhaust as far away from the shift cables as I can
Tuna Helper
Report this Post05-18-2015 08:06 PM Click Here to See the Profile for Tuna HelperSend a Private Message to Tuna HelperEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know, I need to get the repair kit from Rodney.
Found a pair of rams horn style on eBay for about a hundred bucks, just wondering why people don't use them.
