  How does the rear spindle,attach to the lower ball joint on the lower control arm?
How does the rear spindle,attach to the lower ball joint on the lower control arm? by Lou and Blue
Started on: 05-16-2015 10:45 PM
Replies: 5 (480 views)
Last post by: Taijiguy on 05-19-2015 09:10 PM
Lou and Blue
Report this Post05-16-2015 10:45 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Bought a cradle and installed new ball joints on the lower control arms. Now I have to mount the spindles on the ball joint and I'm not sure how they attach. Pics would be very helpful.
Thanks
Louis
Louis Duet
Baldwin, Long Island, NY
"My mind spins like helicopter blades." -G. Rossdale
"Blue" <= '85 Fiero GT
3800sc series 2 swap in progress
"Boo" <= '81 Delorean DMC-12
VIN #5835
Stock PRV engine
Peugot 604 Intake manifold
Exhaust headers
Anti-3rd brake light
Taijiguy
Total ratings: 244
Report this Post05-17-2015 06:30 AM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
No pictures handy, but the spindle just slides down over the ball joint stud. If you look, there's a slight radial cutout on the one side of the stud; that has to line up with the hole in the spindle for the clamping bolt. When you push the bolt through it locks the stud in place. Put the nut on the bolt and tighten it down and everything is held together.
fierosound
Total ratings: 286
Report this Post05-17-2015 11:02 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup... that's how it works.
Calgary time/temp
Lou and Blue
Report this Post05-18-2015 04:02 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you !!!!!!
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
Lou and Blue
Report this Post05-19-2015 08:50 PM Click Here to See the Profile for Lou and BlueSend a Private Message to Lou and BlueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, so if the notch in the ball joint is not in the correct alignment I just grab it with pliers and twist it into place?
Just figured I'd ask before I break something, I'm known for that.
Louis Duet
VIN #5835
Stock PRV engine
Exhaust headers
Taijiguy
Total ratings: 244
Report this Post05-19-2015 09:10 PM Click Here to See the Profile for TaijiguySend a Private Message to TaijiguyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, that stud will rotate, so give it a twist.
