  Right Turn Signal Doesn't Blink
Right Turn Signal Doesn't Blink by coltonandrew
Started on: 05-16-2015 07:20 PM
Replies: 5 (568 views)
Last post by: 2.5 on 05-18-2015 08:57 AM
coltonandrew
Report this Post05-16-2015 07:20 PM Click Here to See the Profile for coltonandrewSend a Private Message to coltonandrewEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello! My right turn signal doesnt blink, but my left does. I've just been making it blink manually. I'm honestly not even sure if the light still comes on on the outside, but the dash indicator lights up (solid if just turned on, flashes if I manually make it)
I know Fieros are electrical nightmares, so I was wondering if this could be a blinker relay or if maybe the bulb is just burnt out? I'm not sure where to start and Kansas has decided to try to flood us again so I con't go out and look right now.
sricka01
Report this Post05-16-2015 07:30 PM Click Here to See the Profile for sricka01Send a Private Message to sricka01Edit/Delete MessageReply w/QuoteDirect Link to This Post
you need to check the bulbs at least before posting.
It can be a crossed filament or bad ground.
Report this Post05-16-2015 08:12 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup...
See my Cave, Sneak Path and Lighbulbs
fierogt28
Report this Post05-17-2015 12:14 AM Click Here to See the Profile for fierogt28Send a Private Message to fierogt28Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, for sure...check the bulb if its burnt out.
If it is, install an new bulb. If it still doesn't light up, do a wiggle test.
Total ratings: 291
Report this Post05-17-2015 08:37 AM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe your blinker fluid is low.
Report this Post05-18-2015 08:57 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
My three Fieros really werent electrical nightmares
Yeah you probably just have a bad bulb, one filament in a bulb can fail and the other still work.
