  JY options for L67 turbo injectors
JY options for L67 turbo injectors by carwhisperer
Started on: 05-15-2015 04:16 PM
Replies: 5 (136 views)
Last post by: mr_corean on 05-16-2015 04:03 PM
carwhisperer
Report this Post05-15-2015 04:16 PM Click Here to See the Profile for carwhispererSend a Private Message to carwhispererEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm hoping to make 400hp on an L67 with a Holset HX40 turbo. Are there any JY options for injectors? I have read that Ford V8 CFI injectors can flow 60 lbs/hr. These were in early to mid 80's Fords. CFI stands for central fuel injection, as in throttle body injection. There are only 2 injectors for a V8 engine so they have a pretty high flow rate. I'm wondering if anyone knows if they will fit.
[This message has been edited by carwhisperer (edited 05-15-2015).]
nosrac
Total ratings: 50
Report this Post05-15-2015 10:49 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's better to find some used GP specific injectors on a grand prix forum or ebay. That way when it comes to tuning its plug and play for the most part.
Justinbart
Total ratings: 119
Report this Post05-16-2015 10:16 AM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is some 80lb siemens on a grand prix facebook page for $200. Might be able t find a used set of 60's for a bit cheaper if you search and wait. I would plan for the future because you know you'll have that up to 600hp in now time.
Turbo 3800 E85 F23 5spd spec5
10.91@133.1
carwhisperer
Report this Post05-16-2015 02:09 PM Click Here to See the Profile for carwhispererSend a Private Message to carwhispererEdit/Delete MessageReply w/QuoteDirect Link to This Post
So do you think I should go 60 or 80? Will I have trouble getting it to idle with 80's? This is going to be a street car.
By the way, can you tell me a little about your setup? 10.91 is pretty fast.
Brian
Justinbart
Total ratings: 119
Report this Post05-16-2015 03:58 PM Click Here to See the Profile for JustinbartSend a Private Message to JustinbartEdit/Delete MessageReply w/QuoteDirect Link to This Post
Brian
I don't think you'll have any issues with idling either. You'll probably never max 60's on pump gas.
click the links in my sig.
10.91@133.1
[This message has been edited by Justinbart (edited 05-16-2015).]
mr_corean
Report this Post05-16-2015 04:03 PM Click Here to See the Profile for mr_coreanSend a Private Message to mr_coreanEdit/Delete MessageReply w/QuoteDirect Link to This Post
I want those 80s. Do you have a link to them?
