  Camaro auto down window modual how do you wire it?
Camaro auto down window modual how do you wire it? by 1Packrat
Started on: 05-08-2015 08:57 PM
Replies: 2 (115 views)
Last post by: CowsPatoot on 05-09-2015 04:50 AM
1Packrat
Report this Post05-08-2015 08:57 PM Click Here to See the Profile for 1PackratSend a Private Message to 1PackratEdit/Delete MessageReply w/QuoteDirect Link to This Post
In Ogre's cave is an article on installing a one touch window module in the Fiero. The author shows that he is using Grand Am window switches. At the end of the article it mentions that you can just add the module using the existing switches. The problem is the author did not list a schematic for using the existing switches only the ones for the Grand Am. Does anyone know how to make the modification using the Fiero switches. If you know how would you please share the information on how to wire it in.
Mike Gonzalez
Total ratings: 130
Report this Post05-08-2015 11:04 PM Click Here to See the Profile for Mike GonzalezSend a Private Message to Mike GonzalezEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe this will help
CowsPatoot
Total ratings: 84
Report this Post05-09-2015 04:50 AM Click Here to See the Profile for CowsPatootClick Here to visit CowsPatoot's HomePageSend a Private Message to CowsPatootEdit/Delete MessageReply w/QuoteDirect Link to This Post
One small problem with that diagram (unless I am reading things wrong). In that diagram, both the up and down side of the switch default to a ground. In the stock Fiero switch, they both default to open. That means that while the express down relay will continue to provide the positive power to lower the window the rest of the way, the window motor won't have the ground to complete the circuit. Also notice that the module itself does not have a ground other than through the switch.
