  L67 swap friends...what to do 4 fuel rails?
L67 swap friends...what to do 4 fuel rails? by OHNIKO
Started on: 05-08-2015 03:14 PM
Replies: 9 (1052 views)
Last post by: OHNIKO on 05-15-2015 01:16 PM
OHNIKO
Report this Post05-08-2015 03:14 PM Click Here to See the Profile for OHNIKOSend a Private Message to OHNIKOEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's my swap set up & upgrades:
1998 series 2 3800 (L67) & 4t65E auto HD tranny from buick regal gs
2007 gen 5 supercharger with N* TB & spacer
2000 N* MAF
3.25" zzp pulley
XP Hot Cam
walbro hi-flo fuel pump
105# comp cam valve springs, pushrods, lifters, mod retainers
zzp 1" short stack intercooler
colder plugs: NGK TR6 V-power
zzp 10mm plug wires
stock heads
cold air intake
low mount alternator
what have you guys done for fuel rails? (the po's fuel lines are on the crappy side, want to do it right...)
use zzp's modified fuel rails setup with my mods?
pix & suggestions welcome?
thanks,
Nick
[This message has been edited by OHNIKO (edited 05-15-2015).]
vette7584
Report this Post05-08-2015 03:22 PM Click Here to See the Profile for vette7584Send a Private Message to vette7584Edit/Delete MessageReply w/QuoteDirect Link to This Post
check out Fierofreak00, he made a custom set for me out of the stock lines, i have an 88 3800sc as well, i am in the build process, i do have a running car. his work is top notch.
DKcustoms
Report this Post05-08-2015 03:38 PM Click Here to See the Profile for DKcustomsSend a Private Message to DKcustomsEdit/Delete MessageReply w/QuoteDirect Link to This Post
www.fiero.nl/forum/Forum4/HTML/065100.html
Fierofreak00, his name is Jason.
You won't be disappointed.
dobey
Total ratings: 371
Report this Post05-08-2015 03:38 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Modified stock, or go with Aeromotive rails tends to be the solutions I've seen.
Report this Post05-08-2015 04:09 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The fuel rails custom made by Jason as very nice looking as are the Aeromotive. Two different styles for different tastes..
[This message has been edited by Dennis LaGrua (edited 05-14-2015).]
OHNIKO
Report this Post05-13-2015 11:20 PM Click Here to See the Profile for OHNIKOSend a Private Message to OHNIKOEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks friends!
so both are Jason's?
[This message has been edited by OHNIKO (edited 05-14-2015).]
carwhisperer
Report this Post05-14-2015 03:38 PM Click Here to See the Profile for carwhispererSend a Private Message to carwhispererEdit/Delete MessageReply w/QuoteDirect Link to This Post
What is wrong with the stock fuel rails?
Report this Post05-14-2015 03:54 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nothing wrong with them but the fuel lines on series II 3800 rails connect in the rear. Some consider this not to be the neatest looking and some use them as they are. If you have a series III 3800 single fuel rail then it is easy to reverse the rail and have the connection in the front. This is how I did my series III swap.
hnthomps
Total ratings: 50
Report this Post05-14-2015 06:49 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
These are the rails that I used on a 3800 SC Series III (N* TV, ZZP intercooler, VS cam, TOG headers, etc.) swap and I like the way that they look.
This is a different fuel rail on a 3800 SC series II engine (basically stock with a 3.4" pulley).
Nelson
[This message has been edited by hnthomps (edited 05-14-2015).]
OHNIKO
Report this Post05-15-2015 01:16 PM Click Here to See the Profile for OHNIKOSend a Private Message to OHNIKOEdit/Delete MessageReply w/QuoteDirect Link to This Post
those set ups look nice!
Jason has been contacted.
I am all for supporting our fellow members in our Fiero community that do good work
thanks folks!
